I am trying to update Ubuntu to 20.04 but it aborts every time I execute
$ sudo do-release-upgrade
The output is:
Checking for a new Ubuntu release
Get:1 Upgrade tool signature [1.554 B]
Get:2 Upgrade tool [1.342 kB]
Fetched 1.344 kB in 0s (0 B/s)
authenticate 'focal.tar.gz' against 'focal.tar.gz.gpg'
extracting 'focal.tar.gz'
Reading cache
Checking package manager
Reading package lists... Done
Building dependency tree
Hit ...
Fetched 64,4 kB in 0s (0 B/s)
Checking for installed snaps
Calculating snap size requirements
Updating repository information
Third party sources disabled
Some third party entries in your sources.list were disabled. You can
re-enable them after the upgrade with the 'software-properties' tool
or your package manager.
To continue please press [ENTER]
Get:1 ...
Fetched 40,6 MB in 6s (6.708 kB/s)
Calculating the changes
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by:
- Unofficial software packages not provided by Ubuntu
Please use the tool 'ppa-purge' from the ppa-purge
package to remove software from a Launchpad PPA and
try the upgrade again.
If none of this applies, then please report this bug using the
command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal. If
you want to investigate this yourself the log files in
'/var/log/dist-upgrade' will contain details about the upgrade.
Specifically, look at 'main.log' and 'apt.log'.
Restoring original system state
Aborting
The main.log states
$ cat /var/log/dist-upgrade/main.log
2020-09-30 16:21:06,928 DEBUG Using 'DistUpgradeViewText' view
2020-09-30 16:21:06,980 DEBUG enable dpkg --force-overwrite
2020-09-30 16:21:07,016 DEBUG creating statefile: '/var/log/dist-upgrade/apt-clone_system_state.tar.gz'
2020-09-30 16:21:14,394 DEBUG lsb-release: 'bionic'
2020-09-30 16:21:14,395 DEBUG _pythonSymlinkCheck run
2020-09-30 16:21:14,395 DEBUG openCache()
2020-09-30 16:21:14,396 DEBUG quirks: running PreCacheOpen
2020-09-30 16:21:14,396 DEBUG running Quirks.PreCacheOpen
2020-09-30 16:21:15,760 DEBUG Comparing 4.15.0-117 with
2020-09-30 16:21:15,761 DEBUG Comparing 4.15.0-118 with 4.15.0-117
2020-09-30 16:21:16,033 DEBUG /openCache(), new cache size 100547
2020-09-30 16:21:16,033 DEBUG need_server_mode(): run in 'desktop' mode, (because of pkg 'ubuntu-desktop')
2020-09-30 16:21:16,033 DEBUG checkViewDepends()
2020-09-30 16:21:16,034 DEBUG running doUpdate() (showErrors=False)
2020-09-30 16:21:19,829 DEBUG openCache()
2020-09-30 16:21:21,156 DEBUG Comparing 4.15.0-117 with
2020-09-30 16:21:21,156 DEBUG Comparing 4.15.0-118 with 4.15.0-117
2020-09-30 16:21:21,506 DEBUG /openCache(), new cache size 100547
2020-09-30 16:21:21,506 DEBUG doPostInitialUpdate
2020-09-30 16:21:21,507 DEBUG quirks: running focalPostInitialUpdate
2020-09-30 16:21:21,507 DEBUG running Quirks.focalPostInitialUpdate
2020-09-30 16:21:23,560 DEBUG Snap core18 is installed
2020-09-30 16:21:23,860 DEBUG Snap gnome-3-34-1804 is installed
2020-09-30 16:21:23,862 DEBUG Snap gnome-3-34-1804 is not tracking the release channel
2020-09-30 16:21:24,068 DEBUG Snap gtk-common-themes is installed
2020-09-30 16:21:24,376 DEBUG Snap snap-store is installed
2020-09-30 16:21:24,376 DEBUG Snap snap-store is not tracking the release channel
2020-09-30 16:21:24,682 DEBUG Snap gnome-3-28-1804 is installed
2020-09-30 16:21:24,683 DEBUG Snap gnome-3-28-1804 is not tracking the release channel
2020-09-30 16:21:24,902 DEBUG Snap gnome-calculator is installed
2020-09-30 16:21:25,089 DEBUG Snap gnome-characters is installed
2020-09-30 16:21:25,298 DEBUG Snap gnome-logs is installed
2020-09-30 16:21:28,247 DEBUG MetaPkgs: ubuntu-desktop
2020-09-30 16:21:36,258 DEBUG Foreign: audio-recorder com.github.babluboy.nutty containerd.io contractor docker-ce docker-ce-cli google-chrome-stable icu-devtools keepassxc krita krita-data libapache2-mod-php libapache2-mod-php5.6 libapache2-mod-php7.0 libapache2-mod-php7.1 libapache2-mod-php7.2 libapache2-mod-php7.3 libapache2-mod-php7.4 libdrm-amdgpu1 libdrm-amdgpu1:i386 libdrm-common libdrm-intel1 libdrm-intel1:i386 libdrm-nouveau2 libdrm-nouveau2:i386 libdrm-radeon1 libdrm-radeon1:i386 libdrm2 libdrm2:i386 libegl-dev libegl-mesa0 libegl1 libegl1-mesa libegl1-mesa-dev libgbm1 libgd3 libgl-dev libgl1 libgl1-mesa-dev libgl1-mesa-dri libgl1-mesa-dri:i386 libgl1-mesa-glx libgl1-mesa-glx:i386 libgl1:i386 libglapi-mesa libglapi-mesa:i386 libgles-dev libgles1 libgles2 libgles2-mesa-dev libglvnd-dev libglvnd0 libglvnd0:i386 libglx-dev libglx-mesa0 libglx-mesa0:i386 libglx0 libglx0:i386 libgranite-common libgranite5 libicu-dev libicu65 libidn2-0 libllvm10 libllvm10:i386 libnorm1 libopengl-dev libopengl0 libpcre16-3 libpcre2-8-0 libpcre3 libpcre3-dev libpcre32-3 libpcre3:i386 libpcrecpp0v5 libpython-stdlib libpython2-stdlib libsodium23 libssl1.1 libwayland-egl1-mesa libxatracker2 libxml2 libxml2-utils libzip4 libzmq5 mesa-va-drivers mesa-vdpau-drivers mesa-vulkan-drivers mesa-vulkan-drivers:i386 meson obs-studio openssl peek php php-apcu php-apcu-bc php-cli php-common php-curl php-gd php-igbinary php-intl php-ldap php-mbstring php-mysql php-redis php-soap php-sqlite3 php-xml php-xmlrpc php-zip php5.6 php5.6-bcmath php5.6-cli php5.6-common php5.6-curl php5.6-gd php5.6-json php5.6-mbstring php5.6-mysql php5.6-opcache php5.6-readline php5.6-soap php5.6-xml php5.6-zip php7.0 php7.0-bcmath php7.0-bz2 php7.0-cli php7.0-common php7.0-curl php7.0-gd php7.0-gmp php7.0-intl php7.0-json php7.0-mbstring php7.0-mcrypt php7.0-mysql php7.0-opcache php7.0-pgsql php7.0-readline php7.0-soap php7.0-xml php7.0-zip php7.1 php7.1-bcmath php7.1-bz2 php7.1-cli php7.1-common php7.1-curl php7.1-gd php7.1-gmp php7.1-intl php7.1-json php7.1-mbstring php7.1-mcrypt php7.1-mysql php7.1-opcache php7.1-pgsql php7.1-readline php7.1-soap php7.1-xml php7.1-zip php7.2 php7.2-bcmath php7.2-cli php7.2-common php7.2-curl php7.2-gd php7.2-json php7.2-mbstring php7.2-mysql php7.2-opcache php7.2-readline php7.2-soap php7.2-xml php7.2-zip php7.3 php7.3-cli php7.3-common php7.3-curl php7.3-gd php7.3-intl php7.3-json php7.3-ldap php7.3-mbstring php7.3-mysql php7.3-opcache php7.3-readline php7.3-soap php7.3-xml php7.3-xmlrpc php7.3-zip php7.4 php7.4-cli php7.4-common php7.4-curl php7.4-gd php7.4-intl php7.4-json php7.4-ldap php7.4-mbstring php7.4-mysql php7.4-opcache php7.4-readline php7.4-soap php7.4-sqlite3 php7.4-xml php7.4-xmlrpc php7.4-zip python python-httplib2 python-minimal python2 python2-minimal python3-httplib2 shotcut spotify-client xserver-xorg-video-amdgpu xserver-xorg-video-ati xserver-xorg-video-intel xserver-xorg-video-nouveau xserver-xorg-video-radeon yarn
2020-09-30 16:21:36,258 DEBUG Obsolete: gifski gitkraken ocenaudio oracle-java8-installer oracle-java8-set-default rambox screamingfrogseospider
2020-09-30 16:21:36,259 DEBUG updateSourcesList()
2020-09-30 16:21:36,278 DEBUG rewriteSourcesList() with mirror_check
2020-09-30 16:21:36,278 DEBUG ['ubuntu-minimal', 'ubuntu-standard']
2020-09-30 16:21:36,278 DEBUG Checking pkg: ubuntu-minimal
2020-09-30 16:21:36,286 DEBUG Checking pkg: ubuntu-standard
2020-09-30 16:21:36,292 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic main restricted'
2020-09-30 16:21:36,292 DEBUG verifySourcesListEntry: deb http://archive.ubuntu.com/ubuntu focal main restricted
2020-09-30 16:21:36,292 DEBUG url_downloadable: http://archive.ubuntu.com/ubuntu/dists/focal/Release
2020-09-30 16:21:36,292 DEBUG s='http' n='archive.ubuntu.com' p='/ubuntu/dists/focal/Release' q='' f=''
2020-09-30 16:21:36,501 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal main restricted' updated to new dist
2020-09-30 16:21:36,501 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted'
2020-09-30 16:21:36,502 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-updates main restricted' updated to new dist
2020-09-30 16:21:36,502 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic universe'
2020-09-30 16:21:36,502 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal universe' updated to new dist
2020-09-30 16:21:36,502 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-updates universe'
2020-09-30 16:21:36,503 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-updates universe' updated to new dist
2020-09-30 16:21:36,503 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic multiverse'
2020-09-30 16:21:36,503 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal multiverse' updated to new dist
2020-09-30 16:21:36,503 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-updates multiverse'
2020-09-30 16:21:36,503 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-updates multiverse' updated to new dist
2020-09-30 16:21:36,503 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse'
2020-09-30 16:21:36,504 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse' updated to new dist
2020-09-30 16:21:36,504 DEBUG examining: 'deb http://archive.canonical.com/ubuntu bionic partner'
2020-09-30 16:21:36,504 DEBUG verifySourcesListEntry: deb http://archive.canonical.com/ubuntu focal partner
2020-09-30 16:21:36,504 DEBUG url_downloadable: http://archive.canonical.com/ubuntu/dists/focal/Release
2020-09-30 16:21:36,505 DEBUG s='http' n='archive.canonical.com' p='/ubuntu/dists/focal/Release' q='' f=''
2020-09-30 16:21:36,703 DEBUG entry 'deb http://archive.canonical.com/ubuntu focal partner' updated to new dist
2020-09-30 16:21:36,704 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-security main restricted'
2020-09-30 16:21:36,704 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-security main restricted' updated to new dist
2020-09-30 16:21:36,704 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-security universe'
2020-09-30 16:21:36,704 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-security universe' updated to new dist
2020-09-30 16:21:36,704 DEBUG examining: 'deb http://archive.ubuntu.com/ubuntu bionic-security multiverse'
2020-09-30 16:21:36,705 DEBUG entry 'deb http://archive.ubuntu.com/ubuntu focal-security multiverse' updated to new dist
2020-09-30 16:21:36,705 DEBUG examining: 'deb [arch=amd64] https://download.docker.com/linux/ubuntu bionic stable'
2020-09-30 16:21:36,708 DEBUG entry '# deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,708 DEBUG examining: 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
2020-09-30 16:21:36,712 DEBUG entry '# deb https://dl.winehq.org/wine-builds/ubuntu/ focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,712 DEBUG examining: 'deb http://ppa.launchpad.net/bablu-boy/nutty/ubuntu bionic main'
2020-09-30 16:21:36,715 DEBUG entry '# deb http://ppa.launchpad.net/bablu-boy/nutty/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,716 DEBUG examining: 'deb http://ppa.launchpad.net/kritalime/ppa/ubuntu bionic main'
2020-09-30 16:21:36,719 DEBUG entry '# deb http://ppa.launchpad.net/kritalime/ppa/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,719 DEBUG examining: 'deb http://ppa.launchpad.net/ondrej/php/ubuntu bionic main'
2020-09-30 16:21:36,722 DEBUG entry '# deb http://ppa.launchpad.net/ondrej/php/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,722 DEBUG examining: 'deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main'
2020-09-30 16:21:36,726 DEBUG entry '# deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,726 DEBUG examining: 'deb http://ppa.launchpad.net/peek-developers/stable/ubuntu bionic main'
2020-09-30 16:21:36,729 DEBUG entry '# deb http://ppa.launchpad.net/peek-developers/stable/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,729 DEBUG examining: 'deb http://repository.spotify.com stable non-free'
2020-09-30 16:21:36,732 DEBUG entry '# deb http://repository.spotify.com stable non-free # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,733 DEBUG examining: 'deb http://ppa.launchpad.net/haraldhv/shotcut/ubuntu bionic main'
2020-09-30 16:21:36,735 DEBUG entry '# deb http://ppa.launchpad.net/haraldhv/shotcut/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,735 DEBUG examining: 'deb http://ppa.launchpad.net/audio-recorder/ppa/ubuntu bionic main'
2020-09-30 16:21:36,738 DEBUG entry '# deb http://ppa.launchpad.net/audio-recorder/ppa/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,738 DEBUG examining: 'deb http://ppa.launchpad.net/phoerious/keepassxc/ubuntu bionic main'
2020-09-30 16:21:36,741 DEBUG entry '# deb http://ppa.launchpad.net/phoerious/keepassxc/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,742 DEBUG examining: 'deb https://dl.yarnpkg.com/debian/ stable main'
2020-09-30 16:21:36,744 DEBUG entry '# deb https://dl.yarnpkg.com/debian/ stable main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,744 DEBUG examining: 'deb http://ppa.launchpad.net/obsproject/obs-studio/ubuntu bionic main'
2020-09-30 16:21:36,746 DEBUG entry '# deb http://ppa.launchpad.net/obsproject/obs-studio/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,746 DEBUG examining: 'deb http://ppa.launchpad.net/elementary-os/stable/ubuntu bionic main'
2020-09-30 16:21:36,748 DEBUG entry '# deb http://ppa.launchpad.net/elementary-os/stable/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:36,748 DEBUG examining: 'deb http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu bionic main'
2020-09-30 16:21:36,750 DEBUG entry '# deb http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu focal main # disabled on upgrade to focal' was disabled (unknown mirror)
2020-09-30 16:21:39,530 DEBUG running doUpdate() (showErrors=True)
2020-09-30 16:21:58,296 DEBUG openCache()
2020-09-30 16:21:59,479 DEBUG Comparing 4.15.0-117 with
2020-09-30 16:21:59,480 DEBUG Comparing 4.15.0-118 with 4.15.0-117
2020-09-30 16:21:59,700 DEBUG /openCache(), new cache size 66591
2020-09-30 16:21:59,700 DEBUG need_server_mode(): run in 'desktop' mode, (because of pkg 'ubuntu-desktop')
2020-09-30 16:21:59,701 DEBUG quirks: running PreDistUpgradeCache
2020-09-30 16:21:59,701 DEBUG running Quirks.PreDistUpgradeCache
2020-09-30 16:21:59,701 INFO installing python-is-python2 because python-minimal was installed
2020-09-30 16:21:59,701 DEBUG Installing 'python-is-python2' (python-minimal was installed on the system)
2020-09-30 16:21:59,765 INFO removing python-minimal because python-is-python2 is being installed
2020-09-30 16:21:59,766 DEBUG Removing 'python-minimal' (python-is-python2 is being installed on the system)
2020-09-30 16:21:59,845 INFO failed to remove python-minimal
2020-09-30 16:22:01,792 DEBUG Installing 'xserver-xorg-video-all' (Distro KeepInstalledPkgs rule)
2020-09-30 16:22:02,057 ERROR Dist-upgrade failed: 'E:Unable to correct problems, you have held broken packages.'
2020-09-30 16:22:02,058 DEBUG abort called
2020-09-30 16:22:02,060 DEBUG openCache()
2020-09-30 16:22:05,217 DEBUG Comparing 4.15.0-117 with
2020-09-30 16:22:05,217 DEBUG Comparing 4.15.0-118 with 4.15.0-117
2020-09-30 16:22:05,498 DEBUG /openCache(), new cache size 100547
Trying to remove python-minimal results in the deletion of half my programs like emma, mysql workbench etc.
All packages are fully updated, all unnecessary packages removed, apt -f returns no errors.
Tried so far:
sudo apt --fix-broken install
sudo apt autoremove
sudo dpkg --get-selections | grep hold
All 3 commands return no errors or warnings.
How to proceed here?
