I decided to switch from using a swap partition, to using a /swapfile.
But there's a problem. The system is still using the swap partition /dev/sda8, and not the /swapfile.
  • I created the /swapfile using the appropriate dd command, etc.
  • I changed /etc/fstab to use /swapfile instead of the old swap partition
  • I changed /etc/initramfs-tools/conf.d/resume to reflect resume=/swapfile
  • I checked that /etc/default/grub has no reference to resume or swap
Yet, when I do swapon -s or free -h, it's still showing /dev/sda8, instead of /swapfile.
Do I need to delete the /dev/sda8 swap partition for this to work?
Does 20.04.1 use any swap partition that it finds, even if it's not in /etc/fstab?
Update #1:
Just to document my /swapfile creation process...
Note: Incorrect use of the dd command can cause data loss. Suggest copy/paste.
In the terminal...
sudo swapoff -a           # turn off swap
sudo rm -i /swapfile      # remove old /swapfile
sudo dd if=/dev/zero of=/swapfile bs=1M count=4096
sudo chmod 600 /swapfile # set proper file protections sudo mkswap /swapfile # init /swapfile sudo swapon /swapfile # turn on swap free -h # confirm 16G RAM and 4G swap
Confirm this /swapfile line at the end of /etc/fstab... and confirm no other “swap” lines...
To edit, use sudo -H gedit /etc/fstab or sudo pico /etc/fstab
/swapfile  none  swap  sw  0  0
reboot                    # reboot and verify operation
Here's my /proc/swaps (and it's fresh from this morning)...
Filename                Type        Size    Used    Priority
/dev/sda8                               partition   9081852 0   -2
Here's the appropriate portion of my /etc/fstab:
# swap was on /dev/sda8 during installation
# UUID=071f8b0e-8e16-4f4d-90ff-a4ae9cc56e2b  none  swap       sw       0       0
Here's my /etc/initramfs-tools/conf.d/resume:
# RESUME=UUID=071f8b0e-8e16-4f4d-90ff-a4ae9cc56e2b
RESUME=/swapfile
sudo update-initramfs -c -k $(uname -r) didn't help.
heynnema
  • 73,649
Well, it's fixed.
When I tried to do a sudo swapoff -a, it gave me a parse error on the following line in my /etc/fstab...
I retyped the line, and made sure to use spaces...
Do you see any difference?
And now it all works!
Thanks for all of the good feedback here!
heynnema
  • 73,649
Did you remove /dev/sda8 from the fstab? You can use sudo swapoff -a and then turn on the swap for the file by typing sudo swapon /swapfile. After that, you can delete/format the partition if all works well.
