62
I am trying to start a program using wine on Ubuntu LTS 12.04 64 bit
When I do this, I get the following error message...
/usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux->gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or >directory
When I try to symlink the 64 bit libraries, of course, I get the following...
jackie@jackie-Latitude-E6410:~/tmp/AC$ wine TTG.exe
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so:
/usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: wrong ELF class: ELFCLASS64
wine: Unhandled page fault on read access to 0x00000000 at address (nil) (thread 0009),
starting debugger...
err:seh:raise_exception Unhandled exception code c0000005 flags 0 addr 0x7bc47aac
Is there a package that installs the 32-bit as well as the 64bit?
UPDATE:
Appears to be a bug in Ubuntu w/ 1.4
https://launchpad.net/~ubuntu-wine/+archive/ppa
I used these steps and my application worked
http://www.noobslab.com/2012/04/install-wine-152-on-ubuntu.html
Not sure exactly why but it appears to ignore the error if you use the 1.5.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Jackie
  • 605
The solution to this needn't be any more complex than:
sudo apt-get install libp11-kit-gnome-keyring
for 64 bit machines. Or
sudo apt-get install libp11-kit-gnome-keyring:i386
for 32 bit machines.
At least this is the case in 13.04 and I see no reason why that wouldn't hold true in 12.04/12.10.
George Udosen
  • 37,534
42
This solution works for Ubuntu 12.04 64bit
I originally had this error:
/usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
Then I did a ln -s link to the 64-bit lib and got this error: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: wrong ELF class: ELFCLASS64
note: before you start remove the link to the 64bit lib if you created it.
Solution:
Here is how to fix it. Note I am using Crossover 11.3, which uses wine 1.4 so it should also work for wine users.
Further related information to getlibs can be found here.
1) Install getlibs:
UODATE 3/2013: Download getlibs from https://github.com/spaetzlecode/getlibs
wget https://raw.github.com/spaetzlecode/getlibs/master/getlibs
sudo chown root:root getlibs
sudo chmod +x getlibs
sudo mv -n getlibs /usr/local/bin
2) Install the 32bit library:
sudo /usr/local/bin/getlibs -p gnome-keyring:i386
If you got this message error:
Failed to download file http://mirrors.kernel.org/ubuntu/pool/main/g/gnome-keyring/gnome-keyring_3.4.1-4ubuntu1~precise1_i386.deb
then download the file right here:
wget https://launchpad.net/~gnome3-team/+archive/gnome3/+files/gnome-keyring_3.4.1-4ubuntu1~precise1_i386.deb
and do:
/usr/local/bin/getlibs -i "path-of-the-file"/gnome-keyring_3.4.1-4ubuntu1~precise1_i386.deb
3) Make the symbolic link:
sudo mkdir -p /usr/lib/i386-linux-gnu/pkcs11/
sudo ln -s /usr/lib32/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so
Now run your Crossover/Wine app and the error is gone.
Evan Carroll
  • 7,703
14
You probably guessed your needed to get the file /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so. This file is part of an i386 ubuntu package which won't install directly on your amd64 system. But you can get it easily:
cd $(mktemp -d)                      ## create and go to a temporary temp dir
apt-get download gnome-keyring:i386  ## download the i386 version of gnome-keyring
ar x gnome-keyring*.deb              ## Uncompress the package
tar xf data.tar.gz
## Finally move the file you need to the desired location:
sudo mv usr/lib/i386-linux-gnu/pkcs11 /usr/lib/i386-linux-gnu/
This has happened to me on a 12.10 with wine-1.5.29, and i386 gnome-keyring version was labeled 3.6.1-0ubuntu1_i386, and this worked for me.
Please note that if these instruction do not fit for you, maybe should you mention your ubuntu release and gnome-keyring version. Thanks !
vaab
  • 1,112
Another option that worked for me is to simply reinstall libp11-kit0
sudo apt-get install --reinstall libp11-kit0
