I am currently using Ubuntu 18.04, and I need gcc 4.8 for MATLAB. So I tried to install gcc-4.8 using
$ sudo apt-get install gcc-4.8
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/l/linux/linux-libc-dev_4.15.0-117.118_amd64.deb  404  Not Found [IP: 2403:8940:3:1::f 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
so I ran the command
sudo apt-get update
I didn't show any error but running gcc version command gave this
$ gcc -v
Command 'gcc' not found, but can be installed with:
sudo apt install gcc
previously I used to have 7.5 but now it is not.
muru
  • 207,228
Open the terminal and type:
sudo apt install linux-libc-dev
sudo apt-get -f install
sudo apt install gcc-4.8
karel
  • 122,292
  • 133
  • 301
  • 332
In your terminal type: sudo apt install gcc and enter. That should install the latest version of gcc.
If you want to install GCC 4.8 specifically, you may follow the post: How to install gcc-4.8.
As GCC 4.8 is available in the default repository on Ubuntu 18.04, then you can simply do
Or type sudo apt-get install gcc-4 in terminal and press tab. If GCC 4.8 is available it will either auto-complete or show the available versions. If there are versions available other than 4.8 as well, add .8 after sudo apt-get install gcc-4 and press enter to install.
hsbasu
  • 125
Today, with Ubuntu 22.04.1 LTS, I can use gcc and gfortran version 4.11.2 with old fortran code. I don't think you should bother with gcc version 4.8.
sudodus
  • 47,684
