-1
my win10 crashed (unmountable boot volume error), so I brutally shut it down, and tried to install ubuntu instead of my win 10 (I do not any back up, just erase and install ubuntu). I downloaded ubuntu iso and created a flash bootable USB from my mac using Etcher. All goes great, till it got stuck in installation with the error: input/output error during read on /dev/sda
from googling around, i understood that my windows is still hibernating and not completely shut-down and this might be the reason for this error. I just want to format this hd and install ubuntu from scratch. is there a way to do it?
Thanks!!
ytytyt
If you want to fix your windows 10 OS, follow This Answer.
Also, you can do this above, and repair the partition. after that, open the Command prompt and type powercfg -h off. it will delete the hiberfile.sys and won't hibernate. probably it can't be fixed, because it's hibernated.
Edit: i already tried this answer on my broken WIndows 7 OS (UNMOUTABLE_BOOT_VOLUME) and it fixed it. i don't know how it will work if the OS is hibernated.
