I updated to Ubuntu 12.04 with Compiz..now Compiz is failing and I have no tool bars or ways of getting to applications except for firefox from a link presented from sending an error report. How am I supposed to:
  1. Fix this mess with no navigation to get to the terminal, or software center.
  2. When will this problem be fixed?
  3. When I updated the system why didn't it change me back to the crappy Unity interface (No offense).
  4. If it can't be fixed how do I get my files back?
Web-E
  • 21,716
Teddy
  • 19
  1. You can goto terminal if no gui is working using shortcut Alt + ctrl + T.
  2. To solve the problem, Reset unity and compiz settings. Every settings of compiz will be resetted.
    • Press Alt + ctrl + F1
    • Login using your username and password
    • Reset compiz by executing gconftool-2 --recursive-unset /apps/compiz-1
    • Reset unity , by executing unity --reset
    • Optionally you can reset launcher icons by executing unity --reset-icons
    • Press Alt + ctrl + F7 to get back to login screen. However I recommend a restart by executing sudo reboot. Let us know if it worked.
  3. When you updated the system, possibly your changes in previous version made some conflicting changes with the update.
  4. You can go to terminal as stated in step 1, and then run nautilus to open the file browser to get your files back.
Web-E
  • 21,716
I tried all of the different "fixes". The only one that worked for me was as follows.
sudo apt-get install nvidia-current
After that and a reboot all GUI was there.
Eliah Kagan
  • 119,640
Heather
In my case the shortcuts were not working. I couldn't even start terminal.
I found the solution here: https://answers.launchpad.net/ubuntu/+question/194996
On fresh install, Ubuntu 12.04 ran Compiz alright. I ran the Update Manager, rebooted and Compiz was good. After installing Additional Drivers, i.e. Nvidia, Compiz crashed and nothing but wallpaper appears. Right-click on screen works and I clicked on Change Desktop Background, then All Settings. I went to Additional Drivers and uninstalled Nvidia. Rebooted and all is well again. Seems like a bug.
