gparted sees the partition 'lvm2', however Dolpin (File Manager) does not see the drive and therefore not mounted.
i reading "You used the exact same name (ubuntu-vg) for your new volume group as the old volume group. You must give them unique names. You can rename one of the groups using vgrename and its UUID." askubuntu.com mount-unknown-filesystem-type-lvm2-member
Find the UUID with vgdisplay and then rename the volume group:
sudo vgdisplay
[sudo] password for administrator:
  /dev/sde: open failed: No medium found
  --- Volume group ---
  VG Name               new_lvm2
  System ID
  Format                lvm2
  Metadata Areas        1
  Metadata Sequence No  5
  VG Access             read/write
  VG Status             resizable
  MAX LV                0
  Cur LV                1
  Open LV               0
  Max PV                0
  Cur PV                1
  Act PV                1
  VG Size               <931,01 GiB
  PE Size               4,00 MiB
  Total PE              238338
  Alloc PE / Size       244 / 976,00 MiB
  Free  PE / Size       238094 / 930,05 GiB
  VG UUID               96qWN4-1W7c-Kwvx-zLeA-9u83-h18g-qBZYAH
vgrename <VG UUID> new_name
sudo vgrename 96qWN4-1W7c-Kwvx-zLeA-9u83-h18g-qBZYAH new_lvm3
  Processing VG new_lvm2 because of matching UUID 96qWN4-1W7c-Kwvx-zLeA-9u83-h18g-qBZYAH
  Volume group "96qWN4-1W7c-Kwvx-zLeA-9u83-h18g-qBZYAH" successfully renamed to "new_lvm3"
gparted sees the partition 'lvm3', however Dolpin (File Manager) does not see the drive and therefore not mounted.
next i tried this: mount unknown filesystem type 'lvm2_member' . means:
sudo bash
vgrename 96qWN4-1W7c-Kwvx-zLeA-9u83-h18g-qBZYAH new_lvm4
modprobe dm-mod
vgchange -ay
lvscan
# Create the mount point directory:
sudo mkdir /mnt/new_lvm4/
# Mount:
mount /dev/new_lvm4/root /mnt/new_lvm4/
Some information about comand before:
# vgchange -ay
  1 logical volume(s) in volume group "new_lvm4" now active
lvscan
/dev/sde: open failed: No medium found ACTIVE '/dev/new_lvm4/swap_1' [976,00 MiB] inherit
mount: /mnt/new_lvm4: special device /dev/new_lvm4/root does not exist. root@administrator-kdeNeon:/home/administrator#
mount /dev/new_lvm4 /mnt/new_lvm4/
mount: /mnt/new_lvm4: /dev/new_lvm4 is not a block device. root@administrator-kdeNeon:/home/administrator#
For this error i reading here:
https://unix.stackexchange.com/questions/30637/mount-error-is-not-a-block-device
and tried:
# mount --bind /dev/new_lvm4 /mnt/new_lvm4/
any idea?
SL5net
  • 698
  • 28
As I told you on matrix: There is no such option to mount a swap device. If you did not see any data LV in your VG then there is nothing to recover.
