I'm trying to upgrade to Ubuntu 20.04 from Ubuntu 18.04.5.
After apt update & apt upgrade, I'm trying to
do-release-upgrade
I get the following error:
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by:
Unofficial software packages not provided by Ubuntu
Please use the tool 'ppa-purge' from the ppa-purge
package to remove software from a Launchpad PPA and
try the upgrade again.
I see that I've previously installed ppa:ubuntu-toolchain-r/test and ppa:hanipouspilot/rtlwifi that cause the issue.
So I try to purge them, but get the following error:
root@ubuntu:~# ppa-purge ppa:ubuntu-toolchain-r/test
Updating packages lists
E: Failed to fetch http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu/dists/bionic/InRelease 403 Forbidden [IP: 91.189.95.83 80]
E: The repository 'http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu bionic InRelease' is not signed.
Warning: apt-get update failed for some reason
root@ubuntu:~# ppa-purge ppa:hanipouspilot/rtlwifi
Looks like the purge is failing as the server is no longer available?
How can I remove the packages manually?
----Edit----- /var/log/dist-upgrade/[CURRENT_DATE]/main.log contains the following errors:
ERROR Dist-upgrade failed: 'E:Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.'
DEBUG abort called
/var/log/dist-upgrade/[CURRENT_DATE]/apt.log contains towards the end
Investigating (5) gsettings-desktop-schemas:amd64 < 3.28.0-1ubuntu1 -> 3.36.0-1ubuntu1 @ii umU Ib >
Broken gsettings-desktop-schemas:amd64 Breaks on mutter:amd64 < 3.28.4-0ubuntu18.04.2 | 3.36.4-0ubuntu0.20.04.2 @ii umH > (< 3.31.4)
Considering mutter:amd64 2 as a solution to gsettings-desktop-schemas:amd64 79
Upgrading mutter:amd64 due to Breaks field in gsettings-desktop-schemas:amd64
Investigating (5) mutter:amd64 < 3.28.4-0ubuntu18.04.2 -> 3.36.4-0ubuntu0.20.04.2 @ii umU Ib >
Broken mutter:amd64 Depends on gnome-settings-daemon-common:amd64 < none | 3.36.1-0ubuntu1 @un uH >
Considering gnome-settings-daemon-common:amd64 0 as a solution to mutter:amd64 2
MarkKeep mutter:amd64 < 3.28.4-0ubuntu18.04.2 -> 3.36.4-0ubuntu0.20.04.2 @ii umU Ib > FU=0
Holding Back mutter:amd64 rather than change gnome-settings-daemon-common:amd64
Investigating (5) gir1.2-mutter-6:amd64 < none -> 3.36.4-0ubuntu0.20.04.2 @un uN Ib >
Broken gir1.2-mutter-6:amd64 Depends on libmutter-6-0:amd64 < none | 3.36.4-0ubuntu0.20.04.2 @un uH > (= 3.36.4-0ubuntu0.20.04.2)
Considering libmutter-6-0:amd64 0 as a solution to gir1.2-mutter-6:amd64 0
MarkKeep gir1.2-mutter-6:amd64 < none -> 3.36.4-0ubuntu0.20.04.2 @un uN Ib > FU=0
Holding Back gir1.2-mutter-6:amd64 rather than change libmutter-6-0:amd64
Investigating (6) gsettings-desktop-schemas:amd64 < 3.28.0-1ubuntu1 -> 3.36.0-1ubuntu1 @ii umU Ib >
Investigating (6) mutter:amd64 < 3.28.4-0ubuntu18.04.2 -> 3.36.4-0ubuntu0.20.04.2 @ii umU Ib >
Investigating (7) gsettings-desktop-schemas:amd64 < 3.28.0-1ubuntu1 -> 3.36.0-1ubuntu1 @ii umU Ib >
Investigating (7) mutter:amd64 < 3.28.4-0ubuntu18.04.2 -> 3.36.4-0ubuntu0.20.04.2 @ii umU Ib >
Investigating (8) gsettings-desktop-schemas:amd64 < 3.28.0-1ubuntu1 -> 3.36.0-1ubuntu1 @ii umU Ib >
Investigating (8) mutter:amd64 < 3.28.4-0ubuntu18.04.2 -> 3.36.4-0ubuntu0.20.04.2 @ii umU Ib >
Investigating (9) gsettings-desktop-schemas:amd64 < 3.28.0-1ubuntu1 -> 3.36.0-1ubuntu1 @ii umU Ib >
Investigating (9) mutter:amd64 < 3.28.4-0ubuntu18.04.2 -> 3.36.4-0ubuntu0.20.04.2 @ii umU Ib >
Done
Thanks! Vitaliy
