I do not believe we have something like that.
This will show when a system was installed:
$ sudo tune2fs -l /dev/sda1 | grep 'Filesystem created:'
Filesystem created: Sat Jun 14 18:29:43 2014
Replace /dev/sda1 with the device name you need (1st column of df / will show you what you want). But I do not believe I ever saw a command to show how long a system has been turned on or off.
uptime
will only show how long the current uptime is.
This will list the last 1000 reboots/shutdowns:
last -1000 reboot shutdown
But that lacks the moment the system was turned on after a shutdown.
edit:
How about an approach like this (it will list the hours a disk has been active):
smartctl --attributes /dev/sda | grep Power_On_Hours
Replace /dev/sda with your device name and install it with sudo apt smartmontools if not available yet. Not totally perfect as it assumes you started using the disk when the system was installed.
