I am having a problem on that whatever the contents of /etc/sudoers file I cannot elevate to sudo with anything, even with a password (wrong password - sorry, try again) though the password is correct.
Below are the contents from /etc/sudoers, which should be correct, unless in combination with other settings are broken. So, it must be something else.
FYI, I installed Puppet on my machine which in the beggining was controlling sudoers to my knowledge, but then I removed monitoring.
My normal privileges user is part of the adm group.
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"
root ALL=(ALL:ALL) ALL
%adm ALL=(ALL) ALL %sudo ALL=(ALL:ALL) ALL
#includedir /etc/sudoers.d
Also, below is the output of /etc/sudoers.d folder and the contents of each file:
root@ns1:/home/vag# ls -la /etc/sudoers.d/
total 28
dr-xr-x---   2 root root  4096 Sep 22 23:46 .
drwxr-xr-x 151 root root 12288 Sep 23 19:19 ..
-r--r-----   1 root root    80 Sep 22 23:46 10_admins
-r--r-----   1 root root    90 Jun  4 20:06 60_mike
-r--r-----   1 root root    91 Jul 10 15:00 99-snapd.conf
root@ns1:/home/vag# cat /etc/sudoers.d/99-snapd.conf
 ##Allow snap-provided applications to work with sudo
Defaults secure_path += /snap/bin root@ns1:/home/vag# cat /etc/sudoers.d/60_mike
This file is managed by Puppet; changes may be overwritten
mike ALL=(ALL) NOPASSWD: ALL root@ns1:/home/vag# cat /etc/sudoers.d/10_admins
%adm ALL=(ALL) ALL
Can you help me to be able to use sudo again without having to "su root" every time?
Regards, Evang
vag
  • 41
I finally got around this by putting rules inside /etc/sudoers.d/ files.
vag
  • 41
