Possible Duplicate:
GRUB: “invalid arch independent ELF magic” after install on SSD
I am currently trying at get a dual boot computer to work, where the Ubuntu 12.04 operating system is spread over two drives.
The setup of the two drives are:
HDD:
/dev/sda1 /boot/efi
/dev/sda2 some unknown msftres at 128MB (don't bother about this as long as the rest works)
/dev/sda3 Windows 7
/dev/sda4 /home
/dev/sda5 swap
/dev/sda6 /tmp
/dev/sda7 /var
SSD:
/dev/sdb1 /
In an attempt to combine speed with SSD durability. That might be a topic in itself, but for now I would be very happy just to get the grub bootloader to work.
When booting at either HDD or SSD, I get this error:
error: invalid arch independent ELF magic.
grub rescue>
karel
  • 122,292
  • 133
  • 301
  • 332
Peter
I had the same problem “invalid arch independent ELF magic”.
I was installing from a USB stick booted from the Bios in UEFI mode.
After a couple a couple unsuccessful reinstallation of 12.04,I tried the same installation with the the USB stick booted without the UEFI mode and it works.
For your information my setting on a 120GB SSD
sda1 /windows 90 GB windows 7 64bits
sda2 /boot 100 MB
sda5 swap 1 GB
sda6 / 18GB ubuntu 12.04
sda7 /home 8GB
My motherboard is P8P67 Pro with Asus EZbios and I had two choices in my boot menu for the USB with 12.04 installation.
Hope it helps!
Snoopy
  • 61
I have fixed the same problem with Backtrack on VMware the boot was broken after installing vmware tools.
I used the following commands :
sudo mount /dev/sda1 /mnt
then
sudo grub-install --root-directory=/mnt /dev/sda
jokerdino
  • 41,732
dr_ggm
  • 31
