I am using ubuntu 18.04 bionic.
I'am getting errors like this with every command.
for example I got this error for the "mkdir" command.
mkdir: cannot create directory ‘/var/lib/apt/lists’: No space left on device
I can not run any command.
I did a lot of research on the internet. none of them worked for me.
My disk status:
Filesystem      Size  Used Avail Use% Mounted on
udev            2.0G     0  2.0G   0% /dev
tmpfs           395M  656K  394M   1% /run
/dev/vda1        78G   14G   65G  17% /
tmpfs           2.0G     0  2.0G   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           2.0G     0  2.0G   0% /sys/fs/cgroup
/dev/vda15      105M  3.6M  101M   4% /boot/efi
tmpfs           395M     0  395M   0% /run/user/0
df -hi
Filesystem     Inodes IUsed IFree IUse% Mounted on
udev             490K   384  490K    1% /dev
tmpfs            494K   631  493K    1% /run
/dev/vda1        9.9M  9.9M     0  100% /
tmpfs            494K     1  494K    1% /dev/shm
tmpfs            494K     4  494K    1% /run/lock
tmpfs            494K    18  494K    1% /sys/fs/cgroup
/dev/vda15          0     0     0     - /boot/efi
tmpfs            494K    11  494K    1% /run/user/0
du
4   ./.config/htop
8   ./.config
4   ./.gnupg/private-keys-v1.d
8   ./.gnupg
4   ./vst_install_backups/1553954077/clamd
4   ./vst_install_backups/1553954077/spamassassin
4   ./vst_install_backups/1553954077/bind
4   ./vst_install_backups/1553954077/postgresql
4   ./vst_install_backups/1553954077/proftpd
4   ./vst_install_backups/1553954077/mysql
4   ./vst_install_backups/1553954077/apache2
4   ./vst_install_backups/1553954077/dovecot
4   ./vst_install_backups/1553954077/exim4
4   ./vst_install_backups/1553954077/vsftpd
4   ./vst_install_backups/1553954077/nginx
4   ./vst_install_backups/1553954077/vesta
4   ./vst_install_backups/1553954077/mongodb
4   ./vst_install_backups/1553954077/php
60  ./vst_install_backups/1553954077
64  ./vst_install_backups
27564   ./.cache/composer/repo/https---repo.packagist.org
27568   ./.cache/composer/repo
124 ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/objects/pack
4   ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/objects/info
132 ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/objects
4   ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/branches
4   ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/refs/heads
4   ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/refs/tags
12  ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/refs
52  ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/hooks
8   ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git/info
228 ./.cache/composer/vcs/https---github.com-bluerhinos-phpMQTT.git
232 ./.cache/composer/vcs
4   ./.cache/composer/files
27812   ./.cache/composer
27816   ./.cache
4   ./.local/share/nano
8   ./.local/share
12  ./.local
16  ./.composer
4   ./.ssh
27964   .
omero
