I want to merge information found here and there in order to record in one answer all steps to set my NFS network between my two Ubuntu PCs
This is useful time to time, for example when switching to a new Ubuntu version, I need to reset :
Boris
  • 5,012
Lets say that «boris» is my logon such as /home/boris is my home folder.
1. set the «server» computer:
  • install nfs-kernel-server and nfs-common
    $ sudo apt-get install nfs-kernel-server
    $ sudo apt-get install nfs-common
  • in /etc/exports, define the folder to be shared by adding this:
    /home/boris   192.168.1.0/24(rw,sync,all_squash,anonuid=1001,anongid=1001,subtree_check)
    with:
    /home/boris is the folder to be shared
    rw for read and write access of the client
    sync ??
    all_squash ??
    192.168.1.0/24 is a range of client computer IP address of your local network
    1001 is the user and group ID. To find it $ id boris
  • manage hosts, 1st allow nobody in /etc/hosts.deny add
    portmap:ALL
    nfsd:ALL
    mountd:ALL
    Then allow your client computer in /etc/hosts.allow add
    portmap:192.168.1.0/24
    lockd:192.168.1.0/24
    nfsd:192.168.1.0/24
    mountd:192.168.1.0/24
    rquotad:192.168.1.0/24
    statd:192.168.1.0/24
    with 192.168.1.0/24 is a range of client computer IP address of your local network
  • set the firewall UFW
    $ sudo ufw enable
    $ sudo ufw default deny incoming
    $ sudo ufw default deny outgoing
    $ sudo ufw allow from 192.168.1.0/24
    $ sudo ufw allow out from 192.168.1.0/24
  • start the server
    $ sudo /etc/init.d/nfs-kernel-server start
    or after a modification of /etc/exports
    $ sudo /etc/init.d/nfs-kernel-server restart
2. set the «client» computer:
  • install nfs-common and autofs
    $ sudo apt-get install autofs
  • create the folder used to mount the connection with the server
    $ sudo mkdir /media/shareFolder
  • set autofs to automatically mount this folder,
    in /etc/auto.master add this line:
    /media/shareFolder /etc/auto.nfs --ghost, --timeout=60
    in /etc/auto.nfs add this line
    boris  -fstype=nfs,rw,intr,uid=1001,guid=1001   192.168.1.1:/home/boris
    with:
    192.168.1.1 is the address of server computer
    /home/boris is the folder shared on server computer.
    $ sudo ufw enable
    $ sudo ufw allow to 192.168.1.1
    $ sudo ufw allow out to 192.168.1.1
    with 192.168.1.1 is the address of the server computer
  • and reboot your client computer.
Boris
  • 5,012
