Whenever I open Software Updater, I get
You stopped the check for updates.
Context:
I opened Software Updater app and there were some updates pending, so I clicked on 'Install Now'. The Software Updater app looked like this after pressing 'Install now':
I couldn't understand if the updates were installing or not. I closed the app and re-opened it. The updates were not installed. I pressed 'Install Now' again and I got the same blank screen (like the above photo). I closed the app and installed the updates using terminal (sudo apt update and then sudo apt upgrade).
Now when I opened the Software Updater app, I got this:
I tried running /usr/bin/update-manager from terminal and got:
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/dbus/bus.py", line 177, in activate_name_owner
return self.get_name_owner(bus_name)
File "/usr/lib/python3/dist-packages/dbus/bus.py", line 361, in get_name_owner
return self.call_blocking(BUS_DAEMON_NAME, BUS_DAEMON_PATH,
File "/usr/lib/python3/dist-packages/dbus/connection.py", line 652, in call_blocking
reply_message = self.send_message_with_reply_and_block(
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.debian.apt': no such name
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/defer/init.py", line 487, in _inline_callbacks
result = gen.send(result)
File "/usr/lib/python3/dist-packages/aptdaemon/client.py", line 1623, in _run_transaction_helper
daemon = get_aptdaemon(self.bus)
File "/usr/lib/python3/dist-packages/aptdaemon/client.py", line 1709, in get_aptdaemon
return dbus.Interface(bus.get_object("org.debian.apt",
File "/usr/lib/python3/dist-packages/dbus/bus.py", line 241, in get_object
return self.ProxyObjectClass(self, bus_name, object_path,
File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 250, in init
self._named_service = conn.activate_name_owner(bus_name)
File "/usr/lib/python3/dist-packages/dbus/bus.py", line 182, in activate_name_owner
self.start_service_by_name(bus_name)
File "/usr/lib/python3/dist-packages/dbus/bus.py", line 277, in start_service_by_name
return (True, self.call_blocking(BUS_DAEMON_NAME, BUS_DAEMON_PATH,
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.Spawn.ChildExited: Launch helper exited with unknown return code 1
File "/usr/lib/python3/dist-packages/aptdaemon/client.py", line 1594, in on_error
error.raise_exception()
File "/usr/lib/python3/dist-packages/defer/init.py", line 130, in raise_exception
raise self.value.with_traceback(self.traceback)
What should I do to fix this issue?
