I connected an HP DeskJet F2410 All-in-one Printer/Scanner through USB to my laptop running Ubuntu 20.04. Running the Document Scanner 3.36.3 detected the scanner as HP DeskJet F2400 Series, however pressing [Scan] only activated scanning in the program and the scanner doesn't scan.
Running hp-check -t reported the following:
narcissan@narcissan-GF63-8RC:~$ hp-check -t
Saving output in log file: /home/narcissan/hp-check.log
HP Linux Imaging and Printing System (ver. 3.20.3)
Dependency/Version Check Utility ver. 15.1
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
- Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION
Status Types:
OK
MISSING - Missing Dependency or Permission or Plug-in
INCOMPAT - Incompatible dependency-version or Plugin-version
warning: ubuntu-20.04 version is not supported. Using ubuntu-19.10 versions dependencies to verify and install...
| SYSTEM INFO |
Kernel: 5.4.0-47-generic #51-Ubuntu SMP Fri Sep 4 19:50:52 UTC 2020 GNU/Linux
Host: narcissan-GF63-8RC
Proc: 5.4.0-47-generic #51-Ubuntu SMP Fri Sep 4 19:50:52 UTC 2020 GNU/Linux
Distribution: ubuntu 20.04
Bitness: 64 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.20.3
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for ubuntu distro 20.04 version
Current contents of '/etc/hp/hplip.conf' file:
hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.20.3
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip
html=/usr/share/doc/hplip-doc
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
apparmor=/etc/apparmor.d
Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=no
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=no
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.20.3
restricted-build=no
ui-toolkit=qt5
qt3=no
qt4=no
qt5=yes
policy-kit=yes
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
apparmor_build=no
class-driver=no
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: No such file or directory
Current contents of '~/.hplip/hplip.conf' file:
[installation]
date_time = 09/20/20 00:24:11
version = 3.20.3
<Package-name> <Package-Desc> <Required/Optional> <Min-Version> <Installed-Version> <Status> <Comment>
| External Dependencies |
error: cups CUPS - Common Unix Printing System REQUIRED 1.1 - INCOMPAT 'CUPS may not be installed or not running'
gs GhostScript - PostScript and PDF language interpreter and previewer REQUIRED 7.05 9.50 OK -
error: xsane xsane - Graphical scanner frontend for SANE OPTIONAL 0.9 - MISSING 'xsane needs to be installed'
scanimage scanimage - Shell scanning program OPTIONAL 1.0 1.0.29 OK -
error: dbus DBus - Message bus system REQUIRED - 1.12.16 MISSING 'DBUS may not be installed or not running'
policykit PolicyKit - Administrative policy framework OPTIONAL - 0.105 OK -
network network -wget OPTIONAL - 1.20.3 OK -
avahi-utils avahi-utils OPTIONAL - 0.7 OK -
| General Dependencies |
error: libjpeg libjpeg - JPEG library REQUIRED - - MISSING 'libjpeg needs to be installed'
error: cups-devel CUPS devel- Common Unix Printing System development files REQUIRED - - MISSING 'cups-devel needs to be installed'
error: cups-image CUPS image - CUPS image development files REQUIRED - - MISSING 'cups-image needs to be installed'
libpthread libpthread - POSIX threads library REQUIRED - b'2.31' OK -
error: libusb libusb - USB library REQUIRED - 1.0 MISSING 'libusb needs to be installed'
sane SANE - Scanning library REQUIRED - - OK -
error: sane-devel SANE - Scanning library development files REQUIRED - - MISSING 'sane-devel needs to be installed'
error: libnetsnmp-devel libnetsnmp-devel - SNMP networking library development files REQUIRED 5.0.9 - MISSING 'libnetsnmp-devel needs to be installed'
error: libcrypto libcrypto - OpenSSL cryptographic library REQUIRED - 1.1.1 MISSING 'libcrypto needs to be installed'
python3X Python 2.2 or greater - Python programming language REQUIRED 2.2 3.8.2 OK -
error: python3-notify2 Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONAL - - MISSING 'python3-notify2 needs to be installed'
error: python3-pyqt4-dbus PyQt 4 DBus - DBus Support for PyQt4 OPTIONAL 4.0 - MISSING 'python3-pyqt4-dbus needs to be installed'
error: python3-pyqt4 PyQt 4- Qt interface for Python (for Qt version 4.x) REQUIRED 4.0 - MISSING 'python3-pyqt4 needs to be installed'
python3-dbus Python DBus - Python bindings for DBus REQUIRED 0.80.0 1.2.16 OK -
python3-xml Python XML libraries REQUIRED - 2.2.9 OK -
python3-devel Python devel - Python development files REQUIRED 2.2 3.8.2 OK -
python3-pil PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL - 7.0.0 OK -
python3-reportlab Reportlab - PDF library for Python OPTIONAL 2.0 3.5.34 OK -
| COMPILEDEP |
error: libtool libtool - Library building support services REQUIRED - - MISSING 'libtool needs to be installed'
gcc gcc - GNU Project C and C++ Compiler REQUIRED - 9.3.0 OK -
make make - GNU make utility to maintain groups of programs REQUIRED 3.0 4.2.1 OK -
| Python Extentions |
cupsext CUPS-Extension REQUIRED - 3.20.3 OK -
hpmudext IO-Extension REQUIRED - 3.20.3 OK -
| Scan Configuration |
'/etc/sane.d/dll.d/hpaio' not found.
hpaio HPLIP-SANE-Backend REQUIRED - 3.20.3 OK 'hpaio found in /etc/sane.d/dll.conf'
scanext Scan-SANE-Extension REQUIRED - 3.20.3 OK -
| DISCOVERED SCANNER DEVICES |
device `hpaio:/usb/Deskjet_F2400_series?serial=CN9AG1201405H4' is a Hewlett-Packard Deskjet_F2400_series all-in-one
| DISCOVERED USB DEVICES |
Device URI Model
hp:/usb/Deskjet_F2400_series?ser HP Deskjet F2400 series
ial=CN9AG1201405H4
| INSTALLED CUPS PRINTER QUEUES |
Deskjet-F2400-series
Type: Printer
Device URI: hp:/usb/Deskjet_F2400_series?serial=CN9AG1201405H4
PPD: /etc/cups/ppd/Deskjet-F2400-series.ppd
warning: Failed to read /etc/cups/ppd/Deskjet-F2400-series.ppd ppd file
PPD Description:
Printer status: printer Deskjet-F2400-series is idle. enabled since Saturday, September 19, 2020 PM11:28:05
Communication status: Good
| PERMISSION |
USB Deskjet-F2400-series Required - - OK Node:'/dev/bus/usb/001/002' Perm:' root lp rw- rw- rw- rw- r--'
| SUMMARY |
Missing Required Dependencies
error: 'libcups2' package is missing/incompatible
error: 'libdbus-1-dev' package is missing/incompatible
error: 'libjpeg-dev' package is missing/incompatible
error: 'libcups2-dev' package is missing/incompatible
error: 'cups-bsd' package is missing/incompatible
error: 'cups-client' package is missing/incompatible
error: 'libcupsimage2-dev' package is missing/incompatible
error: 'libusb-1.0.0-dev' package is missing/incompatible
error: 'libusb-0.1-4' package is missing/incompatible
error: 'libsane-dev' package is missing/incompatible
error: 'libsnmp-dev' package is missing/incompatible
error: 'snmp-mibs-downloader' package is missing/incompatible
error: 'openssl' package is missing/incompatible
error: 'python3-pyqt4' package is missing/incompatible
error: 'gtk2-engines-pixbuf' package is missing/incompatible
error: 'libtool' package is missing/incompatible
error: 'libtool-bin' package is missing/incompatible
Missing Optional Dependencies
error: 'xsane' package is missing/incompatible
error: 'python3-notify2' package is missing/incompatible
error: 'python3-dbus.mainloop.qt' package is missing/incompatible
Total Errors: 14
Total Warnings: 0
Done.
