I just installed Metasploitable 2 from this link on VMware Workstation Pro. After logging in, I tried sudo apt-get install whois and I got this error:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
whois
0 upgraded, 1 newly installed, 0 to remove and 139 not upgraded.
Need to get 31.9kB of archives.
After this operation, 279kB of additional disk space will be used.
WARNING: The following packages could not be authenticated:
whois
Install these packages without verification [y/N]? y
Err http://us.archive.ubuntu.com hardy/main whois 4.7.24
404 Not Found [IP: 91.189.91.38 80]
Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/w/whois/whois_4.7.24_i386.deb 404 Not Found [IP: 91.189.91.38 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
This happens with anything, not just whois.
I tried sudo apt-get update (with and without -fix--missing), and it ends up with a lot of "Failed to fetch" and ends with an error ("Some index files failed to download...").
If I try sudo apt-get upgrade, I get the same result as installing.
I also tried -o Acquire::Check-Valid-Until=false.
The date command returned the time in EDT, 7 hours behind my clock, which is correct.
I am also connected to the internet since I am able to ping 8.8.8.8.
Please can you help me fix it?
