I'm working on this tutorial to setup uWSGI but I'm stuck by this command:
uwsgi --http :8080 --home /home/user/Env/firstsite --chdir /home/user/firstsite -w firstsite.wsgi
first of all, my actual directory path in /home/ubuntu/Es2al2/website, "website": is a project which I work on.
I have no idea what is that command does exactly also, I place my virtual environment into the project itself like so: /home/ubuntu/Es2al2/website/venv/ so, how can I show virtual environment for uWSGI, have I should place my venv like he does by outside the main project or may I place my own venv as I typed in my path?
Note:
"firstsite" is the project that tutorial has created and you can substitute by my real project "website" instead, as I explained.
You don't have to make same exact structure. Just declare your own setup:
uwsgi --http :8080 --home <virtual-env-path> --chdir <django-project-path> -w <django-project-name>.wsgi
So you can go with:
uwsgi --http :8080 --home /home/ubuntu/Es2al2/website/venv --chdir /home/ubuntu/Es2al2/website -w website.wsgi
You can check each option description and how to use it from official doc here: https://uwsgi-docs.readthedocs.io/en/latest/Options.html
user.dz
  • 49,176
