I have a Clevo laptop with an integrated Suyin webcam (064e:3410). The webcam is detected, setting it on/off with Fn+F10 works, but there is no image showing up: the screen remains black with cheese, guvcview, v4l2 test utilities, etc.
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.5 LTS
Release:    18.04
Codename:   bionic
$ uname -a Linux 5.8.0-050800-generic #202008022230 SMP Sun Aug 2 22:33:21 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
$ lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 8087:0a2b Intel Corp. Bus 001 Device 003: ID 064e:3410 Suyin Corp. Bus 001 Device 002: ID 046d:c06c Logitech, Inc. Optical Mouse Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ cheese (cheese:4312): Gtk-WARNING **: 11:16:32.645: Theme parsing error: cheese.css:7:35: The style property GtkScrollbar:min-slider-length is deprecated and shouldn't be used anymore. It will be removed in a future version
$ lsmod | grep video uvcvideo 98304 1 videobuf2_vmalloc 20480 5 uvcvideo videobuf2_memops 20480 1 videobuf2_vmalloc videobuf2_v4l2 28672 1 uvcvideo videobuf2_common 53248 2 videobuf2_v4l2,uvcvideo videodev 245760 4 videobuf2_v4l2,uvcvideo,videobuf2_common mc 57344 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common video 49152 1 i915
Screenshot of cheese showing black screen
I have found these two similar posts, among many others after googling many hours, but no solution so far: Integrated webcam detected but not working and Webcam detected but not showing up
Furthermore, the webcam is reported to work with Debian 10, but I have tried it from a fresh and clean live system (USB stick) and I get the same result: https://linux-hardware.org/index.php?id=usb:064e-3410
Any hint will be much appreciated. Thanks.
Benat
  • 41
If it works with
vlc v4l2:///dev/video0
then you could use OBS Studio to load the VLC v4l2:///dev/video0 and start the virtual webcam.
I had this problem with an ancient Logitech webcam and this was the way I solved the problem.
zx485
  • 2,865
