As a disclaimer I am barely familiar with Linux. I know enough to install my own server and the packages I needed. What I have is:
Distributor ID:   Ubuntu
Description:      Ubuntu 18.04.5 LTS
Release:          18.04
Codename:         bionic
Everytime I log in my welcome screen is:
Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.15.0-117-generic x86_64)
  • Documentation: https://help.ubuntu.com * Management:
https://landscape.canonical.com * Support:
https://ubuntu.com/advantage
System information as of Sat Sep 12 14:25:50 EDT 2020
System load: 0.35 Processes: 167 Usage of /: 24.5% of 228.23GB Users logged in: 0 Memory usage: 32% IP address for wls1: 192.168.0.12 Swap usage: 0%
  • Kubernetes 1.19 is out! Get it in one command with:
    sudo snap install microk8s --channel=1.19 --classic
    https://microk8s.io/ has docs and details.
  • Canonical Livepatch is enabled.
    • All available patches applied.
3 packages can be updated. 0 updates are security updates.
Running apt list --upgradeable returns:
base-files/bionic-updates 10.1ubuntu2.10 amd64 [upgradable from: 10.1ubuntu2.9]
ubuntu-server/bionic-updates 1.417.5 amd64 [upgradable from: 1.417.4]
Other than three update shown above, I do get notified of other updates, and running sudo apt-get upgrade gets and installs all updates, except for the three shown below.
The two commands I use are sudo apt-get upgrade and sudo apt-get update
Can anyone tell me what is wrong, or more likely what it is that I am doing incorrectly?
Here are the results for sudo apt-get update and sudo apt-get update:
server:~$ sudo apt-get update
Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu bionic-security InRelease
 Reading package lists... Done
server:~$ sudo apt-get upgrade
 Building dependency tree
 Calculating upgrade... Done
The following packages have been kept back:
 base-files ubuntu-server
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
server:~$
You want to first run:
sudo apt update
sudo apt dist-upgrade
and then if it doesn't update the packages, run the following command:
sudo apt install base-files ubuntu-server
If there is a problem, it will let you know what the problem is before installing. You will have the option to select Y or N.
If there is no problem, you can select Y and then press ENTER.
mchid
  • 44,904
  • 102
  • 162
