I recently installed Ubuntu on my machine but I am running into a little issue : it doesn't detect any WiFi adaptors. I think it might be because I don't have the right drivers installed. After a little bit of researches on the Internet, I was able to identify the ethernet controller built in my laptop : Realtek Semiconductor TL 8111/8168/8411; and I was this site with (hopefully) the right driver for me : https://www.touslesdrivers.com/index.php?v_page=23&v_code=38271. I downloaded it and I am now left with a file that I don't really know what to do with. I tried to follow the instructions in the README.txt file but couldn't make it work.
Here is what I am faced with :
It says (the README file) : "If you are running the target kernel, then you should be able to do :
    # ./autorun.sh  (as root or with sudo)"
but when I try here is what the terminal says :
titouan@Laptop-Titouan:~/Téléchargements/r8168-8.036.00$ ./autorun.sh
Check old driver and unload it. Build the module and install ./autorun.sh: 27: ./autorun.sh: make: not found titouan@Laptop-Titouan:~/Téléchargements/r8168-8.036.00$ sudo ./autorun.sh [sudo] Mot de passe de titouan :
I don'treally know what to do with this piece of information... Btw I am not even sure the original problem comes from the drivers, but since I don't have any other idea...
Thank you in advance
The issue is with Realtek wireless driver. The driver you described is Ethernet driver.
One possible solution for problem is to found in this answer: https://askubuntu.com/a/1057903/968480
From this repo, you can find driver installation guide. https://github.com/lwfinger/rtw88
Also, some modules might conflict, so they have to be blacklisted with this command:
echo "blacklist ideapad-laptop" | sudo tee -a /etc/modprobe.d/blacklist.conf
From my personal experience with the problem, I could recommend also trying to boot without powercable attatched after all the previous steps (if you run on a laptop of course), altough I don't understand the reasons, but it has worked for me.
