I installed Jupiter to try to improve my laptop's performance, and it's doing rather well :D
However, I use the Radiance theme (white windows, white topbar, black indicator applets etc.) and Jupiter only has a white icon, so I can't really see it... Is there any way for me to change it?
Jorge Castro
  • 73,717
0d_billie
  • 518
Jupiter uses icons from /usr/share/pixmaps/ directory. I've looked through the source code of "Jupiter" and I've found that icon names are hard-coded in application:
def update_icon(self):
    m = self.jupiter.get_current_cpu_mode()
    if m == 'high':
        if loaded_indicator:
            self.ind.set_icon('bolt1')
        else:
            self.tray.set_from_icon_name('bolt1')
    elif m == 'powersave':
            self.ind.set_icon('bolt4')
        else:
            self.tray.set_from_icon_name('bolt4')
    else:
            self.ind.set_icon('bolt2')
        else:
            self.tray.set_from_icon_name('bolt2')
So you can replace the following icons with what you like:
/usr/share/pixmaps/bolt1.png
/usr/share/pixmaps/bolt2.png
/usr/share/pixmaps/bolt3.png
/usr/share/pixmaps/bolt4.png
Surely you can change source code of "jupiter" :)
fasked
  • 151
I just created 3 icons by inverting the colors. Just extract the files in the archive to:
/usr/share/pixmaps/
You need Superuser access to do this and you can download the files here.
Rinzwind
  • 309,379
I've created some new icons here because I didn't like the bold design.
nanofarad
  • 20,906
