ramsudharsan is quite right ...
In my case Ubuntu 20.04
Step 1: Switch to ubuntu recovery mode. If you are unaware of the process, you can refer an answer here: https://askubuntu.com/a/172346/223901
My machine → reboot and [Esc] after splash screen. A little tricky, but after a few attemps GRUB show up ...
Step 2: Once in recovery mode, select root - Drop to root shell prompt
Step 3: Do the following commands
# mount -o remount,rw / → on my machine works without!
chown root:root /usr/bin/sudo
chmod 4755 /usr/bin/sudo
reboot
Step 4: After normal reboot/system start
sudo chmod 4755 /usr/bin/[files from the list below]
also the other files (no complet list):
/usr/bin:
- -rwsr-xr-x 1 root root 84K Jul 15 2021 chfn*
- -rwsr-xr-x 1 root root 52K Jul 15 2021 chsh*
- -rwsr-xr-x 1 root root 39K Mär 7 2020 fusermount*
- -rwsr-xr-x 1 root root 87K Jul 15 2021 gpasswd*
- -rwsr-xr-x 1 root root 310K Okt 11 2019 info*
- -rwsr-xr-x 1 root root 55K Jul 21 2020 mount*
- -rwsr-xr-x 1 root root 44K Jul 15 2021 newgrp*
- -rwsr-xr-x 1 root root 67K Jul 15 2021 passwd*
- -rwsr-xr-x 1 root root 31K Mai 26 2021 pkexec*
- -rwsr-xr-x 1 root root 67K Jul 21 2020 su*
- -rwsr-xr-x 1 root root 163K Jan 19 2021 sudo*
- -rwsr-xr-x 1 root root 39K Jul 21 2020 umount*
- -rwsr-xr-x 1 root root 26K Jan 11 2021 xdg-open*
- -rwsr-xr-x 1 root root 30 Nov 12 2017 xlinks2*
/usr/sbin/:
-rwsr-xr-x 1 root dip 386K Jul 23 2020 pppd
/usr/lib/policykit-1/:
-rwsr-xr-x 1 root root 23K Mai 26 2021 polkit-agent-helper-1
Thanks to the recovery mode, there is no need for a reinstallation! ...
