I am trying to install a Desktop Ubuntu 20.04 with RAID 1 on a PC that has two hard disks of the same size.
I cannot find the dialog in the installer that matches the documentation I read on the subject.
The Ubuntu page https://ubuntu.com/server/docs/installation-advanced says "Follow the installation steps until you get to the Guided storage configuration step".
After the "Keyboard layout" step, I get to the "Updates and other software" step, where I choose "Normal installation". Then I get to "Installation type", where I choose "Erase disk and install Ubuntu". (instead of "Something else"). On the next page I'm asked to select the drive: I can only choose between sda and sdb.
There is no mention of RAID or of a "Guided storage configuration".
Did I take the wrong turn, or am I using the wrong Live DVD?
I downloaded ubuntu-20.04.1-desktop-amd64.iso on Sept. 4th, 2020.
Thanks.
I ended up using the Ubuntu Server installer instead (ubuntu-20.04.1-live-server-amd64.iso).
I followed the instructions by fevangelou at Install Ubuntu 20.04 Focal Fossa with RAID 1 on two devices to create a software RAID.
The server installer worked in text mode, and the system it installed booted in text mode also. I had to do the following to install a graphical desktop:
sudo apt-get update
sudo apt-get install ubuntu-desktop
After rebooting, I got a graphical login and the system appeared to work fine.
To reboot however, I had to power down the PC, because the shutdown had blocked with these lines on the screen:
[FAILED] Failed unmounting /tmp
[FAILED] Failed unmounting /cdrom
Perhaps the Server installer could offer the user to install ubuntu-desktop itself.
I thought the Desktop installer supported creating a software RAID. Perhaps I misremembered, as the last time I had to do that was several years ago.
