ubuntu 18.04 software-properties-gtk failing when I try to open the software&update it doesn't open and when I tried to sudo software-properties-gtk
it return this error
ERROR:dbus.proxies:Introspect error on :1.136:/: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
Traceback (most recent call last):
  File "/usr/bin/software-properties-gtk", line 100, in <module>
    app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
  File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 173, in __init__
    self.backend.Reload();
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 70, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name :1.136 was not provided by any .service files
I tried to reinstall software-properties-gtk but it didn't work I also tried to reinstall python-six packages as recommended by other blogs but also didn't solve my issue.
koub
  • 135
Probably the same issue and the solution is shared here
According to Tim Richardson:
The package python3-six was installed (so my package manager said). when I reinstalled this package, software-properties-gtk worked again.
You may try to install python-six package and reinstall software-properties-gtk aftermath.
sudo apt install python-six
Or you may want to install it via pip
pip install six
After you installed python-six package, reinstall the software-properties-gtk like
sudo apt install --reinstall software-properties-gtk
Hope it solves your problem.
Try the following
sudo apt reinstall python3-six python3-certifi
I had months suffering from this issue on both 18.04 and 20.04. I came by this answer on one of the forums and it worked.
wbadry
  • 270
