I want to use Bombono to author some DVDs, but unlike 16.04 and 18.04, 20.04 doesn't have this package in the repositories. So I downloaded the relevant packages from the 18.04 repos and tried to install them. A regular, non-forced install attempt will be rejected due to unmet dependencies, even though every missing dependency exists in a newer form in 20.04. Using dpkg -i --force-install breaks apt until I remove Bombono. How can I tell dpkg or apt to use these new packages to satisfy the older dependencies?
- 103
This answer will be disappointing. .deb installation packages are recreated for each specific distribution to match dependencies available on the current version. A specific .deb file is designed to connect to specific dependencies. Thus, by design, you cannot have an older .deb use newer dependencies.
Even if you unpack the .deb with the aim to repackage it, the binary code of the application may not work with the current versions of the dependencies, and there is no way you can change/edit these binaries.
For older software that is no longer supported, and that does not anymore run on newer versions, you may have no other option than to attempt recompiling the code on your current system. That may require adapting the program code as well.
- 97,564
