(I just moved from ubuntu 18.04 to Ubuntu 20.04.)
What I can't understand
- The process of how I got to the problem and the detailes are explained below, but I genuinely don't understand the part where it says
php7.4-mysql : Depends: php7.4-common (= 7.4.3-4ubuntu2.2) but 7.4.9-1+ubuntu18.04.1+deb.sury.org+1 is to be installed
- I can understand that the package
php7.4-mysqldependeson php7.4-common(which is installed, so I don't see the problem there), but it also says(= 7.4.3-4ubuntu2.2)and then I'm lost... 7.4.3-4ubuntu2.2? WHAT IS THAT? and if that is not complicated enough it adds...but 7.4.9-1+ubuntu18.04.1+deb.sury.org+1and then I just can't figure out how to move past this.
More insight
- I know a similar questions has been asked, I've read them and the solutions posted don't seem to fix my problem.
I'm trying to use the
$ php artisan migratecommand in a production environment of my own (I hired a hosting and I'm just messing around with it), and I get the output...
Illuminate\Database\QueryException
could not find driver (SQL: select * from information_schema.tables where table_schema = gastigram and table_name = migrations and table_type = 'BASE TABLE')
at vendor/laravel/framework/src/Illuminate/Database/Connection.php:671
667| // If an exception occurs when attempting to run a query, we'll format the error
668| // message to include the bindings with SQL, which will make this exception a
669| // lot more helpful to the developer instead of just the database's errors.
670| catch (Exception $e) {
> 671| throw new QueryException(
672| $query, $this->prepareBindings($bindings), $e
673| );
674| }
675|
+34 vendor frames
35 artisan:37
Illuminate\Foundation\Console\Kernel::handle()
- I googled it and they say is a problem with a missing driver, makes sense... it says right there missing driver, so I tried to install the php7.4-mysql driver but then...
$ sudo apt install php7.4-mysql
Reading package lists... Done
Building dependency tree
How can I solve this problem with the unmet dependency because of a broken package?
Getting help
- I run
$ apt-cache policy php7.4-commonas @guiverc suggested
This is the output
php7.4-common:
Installed: 7.4.9-1+ubuntu18.04.1+deb.sury.org+1
Candidate: 7.4.9-1+ubuntu18.04.1+deb.sury.org+1
Version table:
*** 7.4.9-1+ubuntu18.04.1+deb.sury.org+1 100
100 /var/lib/dpkg/status
7.4.3-4ubuntu2.2 500
500 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
500 http://us.archive.ubuntu.com/ubuntu focal-security/main amd64 Packages
7.4.3-4ubuntu1 500
500 http://us.archive.ubuntu.com/ubuntu focal/main amd64 Packages
