What can I do to configure SSH on both client and servers to prevent Write Failed: broken pipe errors? It often occurs if you sleep your client computer and resume later.
- 29,597
- 10,135
I have tried this in /etc/ssh/ssh_config for Linux and Mac:
Host *
ServerAliveInterval 120
This is how often, in seconds, it should send a keepalive message to the server. If that doesn't work then train a monkey to press enter every two minutes while you work.
You could set either ServerAliveInterval in /etc/ssh/ssh_config of the client machine or ClientAliveInterval in /etc/ssh/sshd_config of the server machine. Try reducing the interval if you are still getting the error.
Configuration for a single user can be set in file ~/.ssh/config both on the server and client side. Make sure the file has correct permissions chmod 644 ~/.ssh/config.
- 103
- 3
- 3,720
SSH sessions may break due to numerous and possibly unavoidable reasons.
A useful utility which can be used to mitigate problems caused by this is called screen. Screen is a powerful utility that allows you to control multiple terminals which will stay alive independently of the ssh session. For example, if you run screen in an ssh session you will see a new terminal open and you can use that to run jobs. Lets say your ssh session dies in the process. Running screen -d then screen -r will reopen the last session and you will be able to continue from there. Make sure you read some of the documentation before using it.
- 3
- 3
- 1,916
Client configuration
Try creating the file:
~/.ssh/config
Add the contents:
Host *
ServerAliveInterval 30
ServerAliveCountMax 5
Now ssh to your server and see if your problem is fixed. ClientAliveInterval option is only useful when configuring the ssh server (aka sshd), it does not change a thing on the ssh client side, so don't use it in the above configuration file.
This will send a hello-are-you-there signal to the server if no packets have been received in the preceding 30 seconds (as specified above). However, if the number of consecutive hello-are-you-there signals reach ServerAliveCountMax then ssh will disconnect from the server. This value is defaulting to 3 (so 3*30 = 90 seconds without server activity), increase it if it suits your needs. There are alot more config options to the .ssh/config file and you could read:
For more information on other options. You may not want to apply this to every server you connect to which this example will. Or restrain it to only a particular server by replacing the line Host * with Host <IP> (replace by an IP address, see ssh_config man page).
Server configuration
Similarly you can tell the server to be gentle with your clients. The configuration file is /etc/ssh/sshd_config.
ClientAliveInterval 20
ClientAliveCountMax 5
You can either deactivate it by setting ClientAliveInterval to 0 or tweak ClientAliveInterval and ClientAliveCountMax to set a maximum ssh client inactivity without responding to the probes. One advantage of this settings over TCPKeepAlive is that the signals are sent through the encrypted channels, so it is less likely to be spoofable.
- 36,890
- 56
- 97
- 151
- 712
I'm remotely upgrading an Ubuntu server from lucid to precise and lost the ssh connection in the middle of the upgrade with the message "Write failed. Broken pipe". ClientAliveInterval and ServerAliveInterval did nothing. The solution is to turn on TCPKeepAlive options in client ssh:
TCPKeepAlive yes
in
/etc/ssh/ssh_config
Hope this will help
- 103
- 4
- 450
For the client, edit your ~/.ssh/config (or /etc/ssh/ssh_config) file as follow:
Host *
TCPKeepAlive yes
TCPKeepAlive - Specifies whether the system should send TCP keepalive messages to the other side. If they are sent, death of the connection or crash of one of the machines will be properly noticed. However, this means that connections will die if the route is down temporarily, and some people find it annoying (The default is 'yes').
ServerAliveInterval - Sets a timeout interval in seconds after which if no data has been received from the server, ssh(1) will send a message through the encrypted channel to request a response from the server. The default is 0, indicating that these messages will not be sent to the server.
For the server, edit your /etc/ssh/sshd_config as:
ClientAliveInterval 600
ClientAliveCountMax 0
If you want ssh client to exit (timeout) automatically after 10 minutes (600 seconds).
ClientAliveCountMax – This indicates the total number of checkalive message sent by the ssh server without getting any response from the ssh client. Default is 3.
ClientAliveInterval – This indicates the timeout in seconds. After x number of seconds, ssh server will send a message to the client asking for response. Deafult is 0 (server will not send message to client to check.).
See also: What do the options ServerAliveInterval and ClientAliveInterval in sshd_config do, precisely?
I absolutely love Mosh. I frequently ssh into a server, close my laptop and go to a cafe, open it up and carry on as if nothing changed.
Mosh (mobile shell)
Remote terminal application that allows roaming, supports intermittent connectivity, and provides intelligent local echo and line editing of user keystrokes.
Mosh is a replacement for SSH. It's more robust and responsive, especially over Wi-Fi, cellular, and long-distance links.
Mosh is free software, available for GNU/Linux, FreeBSD, Solaris, Mac OS X, and Android.
- 301
- 2
- 3
I posted my answer here, as it was not a Ubuntu VM.
ssh -o IPQoS=throughput user@host
- 171
For me, I was getting Write failed: Broken pipe even when I was actively typing in vim or at the shell prompt. I couldn't browse the internet locally either for awhile either. (I was connecting remotely to Ubuntu using Terminal.)
Others in my network stream a lot of video from Netflix and other places. I can't prove it, but I suspect its an ISP or router issue. For example, Verizon and Netflix are pointing fingers at each other for their customer's network problems.
If you've got a dial-up connection and are streaming video or music with a simultaneous SSH or telnet connection, it's inevitable at some point you'll get a broken pipe message. Upgrading my ISPs broadband package seemed to make my broken connection less frequent.
- 1,702
- 2
- 13
- 14
I have a script on the remote server that never seems to fails, regardless of the SSH configuration client or server.
#!/bin/bash
while true; do date; sleep 10; done;
Save it to some dummy.sh file and quickly run it before you minimize the window or move away from it. It will keep printing the current time stamp on the server and keeps your connection alive as long as the connection is not dropped by any other reason. When you get back to that terminal, just hit CTRL+C and keep working.
- 634
You can add these args every time you invoke ssh: -o ServerAliveInterval=15 -o ServerAliveCountMax=3
You don't have to edit /etc/ssh/*config files if you do this.
You can create an bash alias or function or script to make this easy.
E.g. these bash functions, you can add into your .bashrc, do_ssh is used manually to turn on keepalives. do_ssh_pty is used within scripts to set pty and avoid prompts.
do_ssh() {
ssh -o ServerAliveInterval=15 -o ServerAliveCountMax=3 $*
do_ssh_pty() {
ssh -tt -o "BatchMode=yes" -o "StrictHostKeyChecking=no" -o ServerAliveInterval=15 -o ServerAliveCountMax=3 $*
Now do_ssh user@host can be used or do_ssh user@host <args> <command> and keepalives will be active.
- 541
