I cant install any dependency or package on my ubuntu server.
I've tried removing Nginx and all it's components.
I've tried reinstalling it multiple times
I've tried stopping Apache and Nginx
And I've tried restarting the server.
I keep getting the following message:
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xe" for details.
invoke-rc.d: initscript nginx, action "start" failed.
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2020-09-08 21:56:04 BST; 12ms ago
Docs: man:nginx(8)
Process: 88379 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Main PID: 1802 (code=killed, signal=KILL)
Sep 08 21:56:04 Linux systemd[1]: Starting A high performance web server and a reverse proxy server...
Sep 08 21:56:04 Linux nginx[88379]: nginx: [emerg] dlopen() "/usr/share/nginx/modules/ngx_http_geoip_module.so" failed (/usr/share/nginx/modules/ngx_http_geoip_module.so: cannot open shared object file: No such file or directory) in /etc/nginx/modules-enabled/50-mod-http-geoip.conf:1
Sep 08 21:56:04 Linux nginx[88379]: nginx: configuration file /etc/nginx/nginx.conf test failed
Sep 08 21:56:04 Linux systemd[1]: nginx.service: Control process exited, code=exited status=1
Sep 08 21:56:04 Linux systemd[1]: nginx.service: Failed with result 'exit-code'.
Failed to start A high performance web server and a reverse proxy server.
dpkg: error processing package nginx-core (--configure):
installed nginx-core package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nginx:
nginx depends on nginx-core (<< 1.14.0-0ubuntu1.7.1~) | nginx-full (<< 1.14.0-0ubuntu1.7.1~) | nginx-light (<< 1.14.0-0ubuntu1.7.1~) | nginx-extras (<< 1.14.0-0ubuntu1.7.1~); however:
Package nginx-core is not configured yet.
Package nginx-full is not installed.
Package nginx-light is not installed.
Package nginx-extras is not installed.
nginx depends on nginx-core (>= 1.14.0-0ubuntu1.7) | nginx-full (>= 1.14.0-0ubuntu1.7) | nginx-light (>= 1.14.0-0ubuntu1.7) | nginx-extras (>= 1.14.0-0ubuntu1.7); however:
dpkg: error processing package nginx (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for ufw (0.36-0ubuntu0.18.04.1) ...
Processing triggers for ureadahead (0.100.0-21) ...
Processing triggers for systemd (237-3ubuntu10.42) ...
nginx-core
nginx
How do I fix this warning and reinstall nginx?
added apt install libnginx-mod-http-geoip response
root@Linux:/etc/nginx/modules-enabled# apt install libnginx-mod-http-geoip
Reading package lists... Done
Building dependency tree
libnginx-mod-http-geoip is already the newest version (1.14.0-0ubuntu1.7).
The following packages were automatically installed and are no longer required:
linux-azure-5.3-cloud-tools-5.3.0-1035 linux-azure-5.3-tools-5.3.0-1035 linux-cloud-tools-5.3.0-1035-azure linux-image-5.3.0-1035-azure linux-modules-5.3.0-1035-azure linux-modules-extra-5.3.0-1035-azure
linux-tools-5.3.0-1035-azure
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up nginx-core (1.14.0-0ubuntu1.7) ...
Active: failed (Result: exit-code) since Tue 2020-09-08 22:20:40 BST; 11ms ago
Docs: man:nginx(8)
Process: 115846 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Sep 08 22:20:40 Linux systemd[1]: Starting A high performance web server and a reverse proxy server...
Sep 08 22:20:40 Linux nginx[115846]: nginx: [emerg] dlopen() "/usr/share/nginx/modules/ngx_http_image_filter_module.so" failed (/usr/share/nginx/modules/ngx_http_image_filter_module.so: cannot open shared object file: No such file or directory) in /etc/nginx/modules-enabled/50-mod-http-image-filter.conf:1
Sep 08 22:20:40 Linux nginx[115846]: nginx: configuration file /etc/nginx/nginx.conf test failed
Sep 08 22:20:40 Linux systemd[1]: nginx.service: Control process exited, code=exited status=1
Sep 08 22:20:40 Linux systemd[1]: nginx.service: Failed with result 'exit-code'.
Sep 08 22:20:40 Linux systemd[1]: Failed to start A high performance web server and a reverse proxy server.
nginx-core
root@RapioLinux:/etc/nginx/modules-enabled#
also running sudo apt-get install nginx-full returns
root@Linux:/etc/nginx/sites-enabled# sudo apt-get install nginx-full nginx-light nginx-extras
nginx-extras : Conflicts: nginx-full but 1.14.0-0ubuntu1.7 is to be installed
Conflicts: nginx-light but 1.14.0-0ubuntu1.7 is to be installed
nginx-full : Conflicts: nginx-extras but 1.14.0-0ubuntu1.7 is to be installed
nginx-light : Conflicts: nginx-extras but 1.14.0-0ubuntu1.7 is to be installed
