I'm using a window manager and compositor in Ubuntu. I have blur enabled for transparent windows, which means that when I take a screenshot with gnome-screenshot, the content I'm trying to take a picture of is blurred. With xprop, or some other tool, how do I identify the class of the screenshot window so that I can add it to my blur-exclude rule in my compositor config?
When I start xprop, then take a screenshot and click on the screenshot window, I'm prompted with the following, which doesn't give me any information about the class of the window:
$ xprop WM_CLASS
X Error of failed request: BadWindow (invalid Window parameter) Major opcode of failed request: 20 (X_GetProperty) Resource id in failed request: 0x4001a3 Serial number of failed request: 33 Current serial number in output stream: 33
k-a-v
  • 113
The command xprop WM_CLASS will not work as you expect. Consult man xprop to learn how the program works. To obtain the WM_CLASS and filter out any other information, use
xprop | grep WM_CLASS
vanadium
  • 97,564
