I tried to install Office 2016 on Ubuntu 20.04 following the manual installation method described here: https://askubuntu.com/a/1233780. The installation worked quite well and most applications run well as far as I can see. Only Powerpoint will not start.
One thing I could not do was Step 8 in the "Install Office" section:
Using Nautilus go to folder
drive_c/Program Files/Common Files/Microsoft Shared/ClickToRun/and copyAppvIsvSubsystems32.dllandC2R32.dlltodrive_c/Program Files/Microsoft Office/root/Office16/.
My Installation doesn't have a folder "ClickToRun" and I couldn't find the respective dll-files in the entire Playonlinux-drive either. I also do not have the target directory (...root/Office16) in my POL installation.
How to get Powerpoint started?
Here are the program error details:
Unhandled exception: page fault on write access to 0x00000000 in 32-bit code (0x027fd79b).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
EIP:027fd79b ESP:0033f598 EBP:0033f5a4 EFLAGS:00210246( R- -- I Z- -P- )
EAX:00000008 EBX:0033f620 ECX:00000000 EDX:00000000
ESI:031be210 EDI:00000003
Stack dump:
0x0033f598: 025acd26 0033f620 011d9728 0033f5d0
0x0033f5a8: 025ac97e 0033f620 e5895516 10859c1c
0x0033f5b8: 0033f620 10a45788 0033f5b0 0033faf0
0x0033f5c8: 02ecb0f3 00000000 0033f5e0 025ad35f
0x0033f5d8: 011d9f60 00000003 0033f5f4 0200994f
0x0033f5e8: 0033f620 00000003 00000003 0033f604
Backtrace:
=>0 0x027fd79b in mso (+0x25d79b) (0x0033f5a4)
1 0x025ac97e in mso (+0xc97d) (0x0033f5d0)
2 0x025ad35f in mso (+0xd35e) (0x0033f5e0)
3 0x0200994f in mso99lwin32client (+0x994e) (0x0033f5f4)
4 0x025ad25f in mso (+0xd25e) (0x0033f604)
5 0x025aead6 in mso (+0xead5) (0x0033f650)
6 0x025aea65 in mso (+0xea64) (0x0033f674)
7 0x10007190 in ppcore (+0x718f) (0x0033facc)
8 0x10006940 in ppcore (+0x693f) (0x0033fafc)
9 0x10005f80 in ppcore (+0x5f7f) (0x0033fb28)
10 0x10006044 in ppcore (+0x6043) (0x0033fb54)
11 0x100093d5 in ppcore (+0x93d4) (0x0033fb84)
12 0x100093a5 in ppcore (+0x93a4) (0x0033fb9c)
13 0x1000601b in ppcore (+0x601a) (0x0033fdf4)
14 0x100065da in ppcore (+0x65d9) (0x0033fe68)
15 0x004016ed in powerpnt (+0x16ec) (0x0033fe74)
16 0x004016bf in powerpnt (+0x16be) (0x0033fec0)
17 0x7b4664fc call_process_entry+0xb() in kernel32 (0x0033fed8)
18 0x7b467bc6 start_process+0x105() in kernel32 (0x0033ffd8)
19 0x7b46650a start_process_wrapper+0x9() in kernel32 (0x0033ffec)
0x027fd79b: movl $0x1,0x00000000
Modules:
Module Address Debug info Name (204 modules)
PE 400000- 5c5000 Export powerpnt
PE 5d0000- 11c2000 Deferred oart
PE 13f0000- 15c5000 Deferred mso20win32client
PE 15d0000- 18d2000 Deferred mso30win32client
PE 18e0000- 1ff5000 Deferred mso40uiwin32client
PE 2000000- 2598000 Export mso99lwin32client
PE 25a0000- 3352000 Export mso
PE 90b0000- 91df000 Deferred ppintl
PE 91e0000- 931a000 Deferred ppresources
PE 10000000-10b5f000 Export ppcore
ELF 7a800000-7a93e000 Deferred opengl32<elf>
\-PE 7a820000-7a93e000 \ opengl32
ELF 7b400000-7b7f3000 Dwarf kernel32<elf>
\-PE 7b420000-7b7f3000 \ kernel32
ELF 7bc00000-7bd09000 Deferred ntdll<elf>
\-PE 7bc10000-7bd09000 \ ntdll
ELF 7c000000-7c004000 Deferred <wine-loader>
ELF 7d90a000-7d912000 Deferred libxfixes.so.3
ELF 7d912000-7d91f000 Deferred libxcursor.so.1
ELF 7d91f000-7d934000 Deferred libxi.so.6
ELF 7d934000-7d939000 Deferred libxcomposite.so.1
ELF 7d939000-7d948000 Deferred libxrandr.so.2
ELF 7d948000-7d954000 Deferred libxrender.so.1
ELF 7d954000-7d95c000 Deferred libxxf86vm.so.1
ELF 7d95c000-7d961000 Deferred libxinerama.so.1
ELF 7d961000-7d980000 Deferred libbsd.so.0
ELF 7d980000-7d988000 Deferred libxdmcp.so.6
ELF 7d988000-7d98e000 Deferred libxau.so.6
ELF 7d98e000-7d9bd000 Deferred libxcb.so.1
ELF 7d9bd000-7db0c000 Deferred libx11.so.6
ELF 7db0c000-7db23000 Deferred libxext.so.6
ELF 7db4c000-7dbe5000 Deferred winex11<elf>
\-PE 7db60000-7dbe5000 \ winex11
ELF 7dbe5000-7dc04000 Deferred concrt140<elf>
\-PE 7dbf0000-7dc04000 \ concrt140
ELF 7dc04000-7dc2a000 Deferred imm32<elf>
\-PE 7dc10000-7dc2a000 \ imm32
ELF 7dd04000-7dd30000 Deferred libexpat.so.1
ELF 7dd30000-7dd7e000 Deferred libfontconfig.so.1
ELF 7dd7e000-7dd9c000 Deferred libz.so.1
ELF 7dd9c000-7dddb000 Deferred libpng16.so.16
ELF 7dddb000-7dea1000 Deferred libfreetype.so.6
ELF 7deca000-7dede000 Deferred api-ms-win-crt-time-l1-1-0<elf>
\-PE 7ded0000-7dede000 \ api-ms-win-crt-time-l1-1-0
ELF 7dede000-7df55000 Deferred shlwapi<elf>
\-PE 7def0000-7df55000 \ shlwapi
ELF 7df55000-7dff1000 Deferred gdiplus<elf>
\-PE 7df60000-7dff1000 \ gdiplus
ELF 7dff1000-7e008000 Deferred api-ms-win-crt-multibyte-l1-1-0<elf>
\-PE 7e000000-7e008000 \ api-ms-win-crt-multibyte-l1-1-0
ELF 7e008000-7e01e000 Deferred api-ms-win-crt-convert-l1-1-0<elf>
\-PE 7e010000-7e01e000 \ api-ms-win-crt-convert-l1-1-0
ELF 7e01e000-7e032000 Deferred api-ms-win-crt-utility-l1-1-0<elf>
\-PE 7e020000-7e032000 \ api-ms-win-crt-utility-l1-1-0
ELF 7e032000-7e048000 Deferred api-ms-win-crt-string-l1-1-0<elf>
\-PE 7e040000-7e048000 \ api-ms-win-crt-string-l1-1-0
ELF 7e048000-7e143000 Deferred msvcr120<elf>
\-PE 7e060000-7e143000 \ msvcr120
ELF 7e143000-7e268000 Deferred msvcp140<elf>
\-PE 7e180000-7e268000 \ msvcp140
ELF 7e268000-7e2ef000 Deferred rpcrt4<elf>
\-PE 7e270000-7e2ef000 \ rpcrt4
ELF 7e2ef000-7e309000 Deferred version<elf>
\-PE 7e2f0000-7e309000 \ version
ELF 7e309000-7e512000 Deferred user32<elf>
\-PE 7e320000-7e512000 \ user32
ELF 7e512000-7e679000 Deferred ole32<elf>
\-PE 7e530000-7e679000 \ ole32
ELF 7e679000-7e7c9000 Deferred gdi32<elf>
\-PE 7e690000-7e7c9000 \ gdi32
ELF 7e7c9000-7e843000 Deferred advapi32<elf>
\-PE 7e7e0000-7e843000 \ advapi32
ELF 7e843000-7e857000 Deferred api-ms-win-crt-heap-l1-1-0<elf>
\-PE 7e850000-7e857000 \ api-ms-win-crt-heap-l1-1-0
ELF 7e857000-7e86b000 Deferred api-ms-win-crt-locale-l1-1-0<elf>
\-PE 7e860000-7e86b000 \ api-ms-win-crt-locale-l1-1-0
ELF 7e86b000-7e881000 Deferred api-ms-win-crt-stdio-l1-1-0<elf>
\-PE 7e870000-7e881000 \ api-ms-win-crt-stdio-l1-1-0
ELF 7e881000-7e89a000 Deferred api-ms-win-crt-math-l1-1-0<elf>
\-PE 7e890000-7e89a000 \ api-ms-win-crt-math-l1-1-0
ELF 7e89a000-7e8b0000 Deferred api-ms-win-crt-runtime-l1-1-0<elf>
\-PE 7e8a0000-7e8b0000 \ api-ms-win-crt-runtime-l1-1-0
ELF 7e8b0000-7e9b8000 Deferred ucrtbase<elf>
\-PE 7e8d0000-7e9b8000 \ ucrtbase
ELF 7ee86000-7ee9b000 Deferred libnss_files.so.2
ELF 7ee9b000-7eeb8000 Deferred libnsl.so.1
ELF 7eeb8000-7eec7000 Deferred libnss_nis.so.2
ELF 7eec7000-7eed2000 Deferred libnss_compat.so.2
ELF 7eed2000-7efd7000 Deferred libm.so.6
ELF 7efe0000-7efea000 Deferred libuuid.so.1
ELF 7efea000-7f000000 Deferred vcruntime140<elf>
\-PE 7eff0000-7f000000 \ vcruntime140
ELF ed143000-ed1b4000 Deferred dbghelp<elf>
\-PE ed150000-ed1b4000 \ dbghelp
ELF ed1b4000-ed1ec000 Deferred mscoree<elf>
\-PE ed1c0000-ed1ec000 \ mscoree
ELF ed350000-ed3a6000 Deferred libgssapi_krb5.so.2
ELF ed3a6000-ed3b5000 Deferred libkrb5support.so.0
ELF ed3b5000-ed496000 Deferred libkrb5.so.3
ELF ed496000-ed526000 Deferred libgmp.so.10
ELF ed526000-ed6a8000 Deferred libunistring.so.2
ELF ed6a8000-ed800000 Deferred libp11-kit.so.0
ELF ed800000-eda00000 Deferred libgnutls.so.30
ELF edb01000-edb35000 Deferred libk5crypto.so.3
ELF edb5e000-edb97000 Deferred libhogweed.so.5
ELF edb97000-edbd7000 Deferred libnettle.so.7
ELF edbe5000-edc00000 Deferred kerberos<elf>
\-PE edbf0000-edc00000 \ kerberos
ELF ee003000-ee023000 Deferred libidn2.so.0
ELF ee023000-ee08f000 Deferred dwrite<elf>
\-PE ee030000-ee08f000 \ dwrite
ELF eea04000-eea1d000 Deferred libresolv.so.2
ELF ef2bd000-ef2d4000 Deferred libtasn1.so.6
ELF ef2d4000-ef300000 Deferred iphlpapi<elf>
\-PE ef2e0000-ef300000 \ iphlpapi
ELF ef406000-ef40c000 Deferred libkeyutils.so.1
ELF ef40c000-ef412000 Deferred libcom_err.so.2
ELF f0703000-f0734000 Deferred netapi32<elf>
\-PE f0710000-f0734000 \ netapi32
ELF f0734000-f076b000 Deferred secur32<elf>
\-PE f0740000-f076b000 \ secur32
ELF f0f6c000-f0f95000 Deferred libtinfo.so.6
ELF f0f95000-f0fa0000 Deferred librt.so.1
ELF f0fa0000-f0fd8000 Deferred libedit.so.2
ELF f0fd8000-f0fe2000 Deferred libffi.so.7
ELF f0fe2000-f0fed000 Deferred libatomic.so.1
ELF f0fed000-f100c000 Deferred libgcc_s.so.1
ELF f11ea000-f1247000 Deferred libvulkan.so.1
ELF f1247000-f1251000 Deferred libdrm_nouveau.so.2
ELF f1251000-f125e000 Deferred libdrm_amdgpu.so.1
ELF f125e000-f127c000 Deferred libelf.so.1
ELF f127c000-f1323000 Deferred libzstd.so.1
ELF f1323000-f54f4000 Deferred libllvm-10.so.1
ELF f551d000-f6ce3000 Deferred r600_dri.so
ELF f6ce3000-f6ce6000 Deferred libxshmfence.so.1
ELF f6ce6000-f6cef000 Deferred libxcb-sync.so.1
ELF f6cef000-f6cf4000 Deferred libxcb-present.so.0
ELF f6cf4000-f6cfa000 Deferred libxcb-dri3.so.0
ELF f6cfa000-f6cff000 Deferred libxdamage.so.1
ELF f6cff000-f6d1e000 Deferred libxcb-glx.so.0
ELF f6d1e000-f6d34000 Deferred libdrm.so.2
ELF f6d34000-f6d5d000 Deferred libglapi.so.0
ELF f6d5d000-f6ddd000 Deferred libglx_mesa.so.0
ELF f6ddd000-f6e19000 Deferred libglx.so.0
ELF f6e19000-f6e96000 Deferred libgldispatch.so.0
ELF f6e96000-f6f03000 Deferred libgl.so.1
ELF f6f03000-f6f13000 Deferred libdrm_radeon.so.1
ELF f6f13000-f6f25000 Deferred libsensors.so.5
ELF f6f2c000-f6f44000 Deferred wtsapi32<elf>
\-PE f6f30000-f6f44000 \ wtsapi32
ELF f6f44000-f6fc5000 Deferred d3dcompiler_43<elf>
\-PE f6f50000-f6fc5000 \ d3dcompiler_43
ELF f6fc5000-f700d000 Deferred d3d10<elf>
\-PE f6fd0000-f700d000 \ d3d10
ELF f700d000-f717c000 Deferred wined3d<elf>
\-PE f7020000-f717c000 \ wined3d
ELF f717c000-f71ab000 Deferred dxgi<elf>
\-PE f7180000-f71ab000 \ dxgi
ELF f71ab000-f721b000 Deferred d3d11<elf>
\-PE f71b0000-f721b000 \ d3d11
ELF f721b000-f7231000 Deferred d3d10core<elf>
\-PE f7220000-f7231000 \ d3d10core
ELF f7231000-f7247000 Deferred d3d10_1<elf>
\-PE f7240000-f7247000 \ d3d10_1
ELF f7247000-f72a8000 Deferred d2d1<elf>
\-PE f7250000-f72a8000 \ d2d1
ELF f72a8000-f72e0000 Deferred uxtheme<elf>
\-PE f72b0000-f72e0000 \ uxtheme
ELF f72e0000-f7306000 Deferred cabinet<elf>
\-PE f72f0000-f7306000 \ cabinet
ELF f7306000-f7352000 Deferred usp10<elf>
\-PE f7310000-f7352000 \ usp10
ELF f7352000-f74a2000 Deferred comctl32<elf>
\-PE f7360000-f74a2000 \ comctl32
ELF f74a2000-f74dc000 Deferred ws2_32<elf>
\-PE f74b0000-f74dc000 \ ws2_32
ELF f74dc000-f7504000 Deferred mpr<elf>
\-PE f74e0000-f7504000 \ mpr
ELF f7504000-f7585000 Deferred wininet<elf>
\-PE f7510000-f7585000 \ wininet
ELF f7585000-f77dd000 Deferred shell32<elf>
\-PE f7590000-f77dd000 \ shell32
ELF f77dd000-f787e000 Deferred urlmon<elf>
\-PE f77f0000-f787e000 \ urlmon
ELF f787e000-f79a7000 Deferred msi<elf>
\-PE f7890000-f79a7000 \ msi
ELF f79a7000-f79bc000 Deferred slc<elf>
\-PE f79b0000-f79bc000 \ slc
ELF f79bc000-f79d0000 Deferred msimg32<elf>
\-PE f79c0000-f79d0000 \ msimg32
ELF f79d0000-f79e4000 Deferred api-ms-win-crt-environment-l1-1-0<elf>
\-PE f79e0000-f79e4000 \ api-ms-win-crt-environment-l1-1-0
ELF f79e4000-f7b20000 Deferred oleaut32<elf>
\-PE f7a00000-f7b20000 \ oleaut32
ELF f7b29000-f7b2f000 Deferred libdl.so.2
ELF f7b2f000-f7d1d000 Deferred libc.so.6
ELF f7d1d000-f7d40000 Deferred libpthread.so.0
ELF f7d40000-f7d47000 Deferred libxcb-dri2.so.0
ELF f7d47000-f7d4c000 Deferred libx11-xcb.so.1
ELF f7d4c000-f7d60000 Deferred api-ms-win-crt-filesystem-l1-1-0<elf>
\-PE f7d50000-f7d60000 \ api-ms-win-crt-filesystem-l1-1-0
ELF f7d69000-f7f21000 Dwarf libwine.so.1
ELF f7f23000-f7f50000 Deferred ld-linux.so.2
ELF f7f53000-f7f54000 Deferred [vdso].so
Threads:
process tid prio (all id:s are in hex)
00000008 POWERPNT.EXE
00000009 0
0000000e services.exe
00000023 0
0000001e 0
00000018 0
00000013 0
00000010 0
0000000f 0
00000011 winedevice.exe
0000001d 0
00000017 0
00000016 0
00000012 0
0000001b plugplay.exe
00000020 0
0000001f 0
0000001c 0
00000021 winedevice.exe
00000028 0
00000025 0
00000024 0
00000022 0
00000029 explorer.exe
0000002d 0
0000002c 0
0000002b 0
0000002a 0
0000002e (D) C:\Program Files\Microsoft Office\Office16\POWERPNT.EXE
00000036 1
00000035 0
00000034 0
00000033 0
00000032 0
00000031 0
00000030 0
0000002f 0 <==
System information:
Wine build: wine-3.4
Platform: i386
Version: Windows 7
Host system: Linux
Host version: 5.4.0-45-generic
