Given that Jitsi won't install nicely from apt how is the desktop client currently installed?
There's mention above of using the unstable repo.
These directions won't work for at least one other:
Jitsi
Download
Development
Documentation
    Support and Custom Development
To use our debian/ubuntu stable repository:
install the Jitsi repository key onto your system
wget -qO - https://download.jitsi.org/jitsi-key.gpg.key | sudo apt-key add -
create sources.list.d file with the repository
sudo sh -c "echo 'deb https://download.jitsi.org stable/' > /etc/apt/sources.list.d/jitsi-stable.list"
update your package list
sudo apt-get -y update
install Jitsi
sudo apt-get -y install jitsi
Adding both repos:
nicholas $
nicholas $  wget -qO - https://download.jitsi.org/jitsi-key.gpg.key | sudo apt-key add -
OK
nicholas $
nicholas $  sudo sh -c "echo 'deb https://download.jitsi.org stable/' > /etc/apt/sources.list.d/jitsi-stable.list"
nicholas $
nicholas $  sudo sh -c "echo 'deb https://download.jitsi.org unstable/' > /etc/apt/sources.list.d/jitsi-unstable.list"
nicholas $
commenting out the stable repo and updating:
nicholas $
nicholas $ cat /etc/apt/sources.list.d/jitsi-stable.list
#deb https://download.jitsi.org stable/
nicholas $
nicholas $ sudo apt update
Hit:1 https://download.jitsi.org unstable/ InRelease
Hit:2 http://archive.canonical.com/ubuntu focal InRelease
Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
Hit:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Reading package lists... Done
Building dependency tree
214 packages can be upgraded. Run 'apt list --upgradable' to see them.
nicholas $
and then trying to install:
nicholas $
nicholas $ sudo apt install jitsi
The following information may help resolve the situation:
The following packages have unmet dependencies: jitsi : Depends: libavformat57 but it is not installable or libavformat-ffmpeg56 but it is not installable Depends: libavcodec57 but it is not installable or libavcodec-extra57 but it is not installable or libavcodec-ffmpeg56 but it is not installable or libavcodec-ffmpeg-extra56 but it is not installable Depends: libavfilter6 but it is not installable or libavfilter-extra6 but it is not installable or libavfilter-ffmpeg5 but it is not installable Depends: libavutil55 but it is not installable or libavutil-ffmpeg54 but it is not installable Depends: libswscale4 but it is not installable or libswscale-ffmpeg3 but it is not installable E: Unable to correct problems, you have held broken packages. nicholas $
which then has unmet dependencies. Oh, the unstable repo:
nicholas $
nicholas $ cat /etc/apt/sources.list.d/jitsi-unstable.list
nicholas $
https://desktop.jitsi.org/Main/DebianRepository.html
Both `universe` and `multiverse` are enabled as:
nicholas $ nicholas $ nicholas $ sudo add-apt-repository universe 'universe' distribution component is already enabled for all sources. nicholas $ nicholas $ sudo add-apt-repository multiverse 'multiverse' distribution component is already enabled for all sources. nicholas $ nicholas $ cat /etc/apt/sources.list
#deb http://ag-projects.com/ubuntu focal main
deb http://archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-updates main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb http://archive.canonical.com/ubuntu focal partner deb-src http://archive.canonical.com/ubuntu focal partner
#deb cdrom:[Ubuntu 20.04 LTS Focal Fossa - Release amd64 (20200423)]/ focal main restricted
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
#deb http://ca.archive.ubuntu.com/ubuntu/ focal main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal main restricted
Major bug fix updates produced after the final release of the
distribution.
#deb http://ca.archive.ubuntu.com/ubuntu/ focal-updates main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
#deb http://ca.archive.ubuntu.com/ubuntu/ focal universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal universe
#deb http://ca.archive.ubuntu.com/ubuntu/ focal-updates universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
#deb http://ca.archive.ubuntu.com/ubuntu/ focal multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal multiverse
#deb http://ca.archive.ubuntu.com/ubuntu/ focal-updates multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
#deb http://ca.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
#deb http://security.ubuntu.com/ubuntu focal-security main restricted
deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
#deb http://security.ubuntu.com/ubuntu focal-security universe
deb-src http://security.ubuntu.com/ubuntu focal-security universe
#deb http://security.ubuntu.com/ubuntu focal-security multiverse
deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
This system was installed using small removable media
(e.g. netinst, live or single CD). The matching "deb cdrom"
entries were disabled at the end of the installation process.
For information about how to configure apt package sources,
see the sources.list(5) manual.
nicholas $
The development of Jitsi Desktop (formerly SIP Communicator) ceased in the year 2017. It remained as hobby project (source) and to rip out code for other projects like Jitsi Meet. Therefore, if you really want to use Jitsi Desktop, consider to go for Ubuntu 16.04 EMS which is free (source) and an option till the year 2024. When it comes to newer Ubuntu versions:
Ubuntu 18.04 LTS
sudo apt install openjdk-8-jre libavcodec-extra libavfilter-extra libappindicator1
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/amd64:/usr/lib/jvm/java-8-openjdk-i386/jre/lib/i386
wget download.jitsi.org/unstable/jitsi-archive-keyring_1.0.1_all.deb
sudo dpkg --install ./jitsi-archive-keyring_1.0.1_all.deb
wget download.jitsi.org/unstable/jitsi_2.11.5624-1_amd64.deb
sudo dpkg --install ./jitsi_2.11.5624-1_amd64.deb
jitsi --debug
I have not tested what happens if the default JRE is installed, which is Java 11. If you run into issues, go for sudo update-alternatives --config java and change to Java 8.
Ubuntu 20.04 LTS
Same steps as for Ubuntu 18.04 LTS but one more thing:
a) H.264 video support: not required
You do not need the dependencies to FFmpeg, because those are just recommended libraries. Unluckily the Debian control file is wrong which declares those dependencies as required. Consequently, to run Jitsi Desktop edit that file…
b) H.264 video support: required
If you need the H.264 video codec (or the AMR-WB audio codec), you have to download the jitsi-lgpl-dependencies and compile Jitsi Desktop yourself:
sudo apt install build-essential openjdk-8-jdk ant libavcodec-extra libavfilter-extra libappindicator1
export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64
optionally (if another Java was installed, change to Java 8)
sudo update-alternatives --config javac sudo update-alternatives --config java
optionally (when you have to re-build Jitsi Desktop)
rm -rf ~/.m2
wget github.com/jitsi/jitsi/archive/3ebd5dfac749e0677377dbc8643dfbbbf4b450fa.tar.gz tar -xf 3ebd5dfac749e0677377dbc8643dfbbbf4b450fa.tar.gz cd ./jitsi/
replace the following file:
./lib/installer-exclude/jitsi-lgpl-dependencies-1.2-1-gfc49658.jar
ant make ant -Dargs="--debug" run
Because the head of Jitsi Desktop is untested, compile errors can happen any day. Then, comment here and I have a look what is broken.
