I'm having a problem to install docker in Ubuntu 20.04.
wolf@linux:~$ sudo apt install docker.io
Reading package lists... Done
Building dependency tree
docker.io : Depends: containerd (>= 1.2.6-0ubuntu1~)
wolf@linux:~$
Error message says that I need containerd (>= 1.2.6-0ubuntu1~)
It's strange as I already have even newer version which is 1.2.13-2
wolf@linux:~$ dpkg -l containerd.io
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii containerd.io 1.2.13-2 amd64 An open and reliable container runtime
wolf@linux:~$
The system is updated. I already performed sudo apt update && sudo apt upgrade and no new update required.
Update as requested in comment
wolf@linux:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.1 LTS
Release: 20.04
Codename: focal
wolf@linux:~$
