33
Today I did a fresh install of ubuntu 12.04 and went about setting up my local development environment. I installed mysql and edited /etc/mysql/my.cnf to optimise InnoDB but when I try to restart mysql, it fails with a error:
[20:53][tom@Pochama:/var/www/website] (master) $ sudo service mysql restart
start: Job failed to start
The syslog reveals there is a problem with the init script:
> tail -f /var/log/syslog
Apr 28 21:17:46 Pochama kernel: [11840.884524] type=1400 audit(1335644266.033:184): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/mysqld" pid=760 comm="apparmor_parser"
Apr 28 21:17:47 Pochama kernel: [11842.603773] init: mysql main process (764) terminated with status 7
Apr 28 21:17:47 Pochama kernel: [11842.603841] init: mysql main process ended, respawning
Apr 28 21:17:48 Pochama kernel: [11842.932462] init: mysql post-start process (765) terminated with status 1
Apr 28 21:17:48 Pochama kernel: [11842.950393] type=1400 audit(1335644268.101:185): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/mysqld" pid=811 comm="apparmor_parser"
Apr 28 21:17:49 Pochama kernel: [11844.656598] init: mysql main process (815) terminated with status 7
Apr 28 21:17:49 Pochama kernel: [11844.656665] init: mysql main process ended, respawning
Apr 28 21:17:50 Pochama kernel: [11845.004435] init: mysql post-start process (816) terminated with status 1
Apr 28 21:17:50 Pochama kernel: [11845.021777] type=1400 audit(1335644270.173:186): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/mysqld" pid=865 comm="apparmor_parser"
Apr 28 21:17:51 Pochama kernel: [11846.721982] init: mysql main process (871) terminated with status 7
Apr 28 21:17:51 Pochama kernel: [11846.722001] init: mysql respawning too fast, stopped
Any ideas?
Things I tried already:
I googled and found a Ubuntu bug with apparmor (https://bugs.launchpad.net/ubuntu/+source/mysql-5.5/+bug/970366), I changed apparmor from enforce mode to complain mode:
sudo apt-get install apparmor-utils
sudo aa-complain /usr/sbin/mysqld
sudo /etc/init.d/apparmor reload
but it didn't help. I still can't start mysql.
I also thought the issue may be because the InnoDB logfiles were a different size than mysql was expecting. I removed the innodb log files before restarting using: sudo mv /var/lib/mysql/ib_logfile* /tmp. No luck though.
Workaround: I re-installed 12.04, made sure not to touch /etc/mysql/my.cnf in any way. Mysql is working so I can get on with what I need to do. But I will need to edit it at some point - Hopefully I'll have figured out a solution, or this question will have been answered by that point...
Jorge Castro
  • 73,717
Tom
  • 5,077
18 Answers18
29
I finally figured out the issue. Basically, the definition of some parameters has been removed from the previous version of mysql and has been replaced with different names. To fix, in /etc/mysql/my.cnf, replace:
# Tom Added to ensure the server character set is set to utf8
default-character-set = utf8
default-collation     = utf8_general_ci
with:
character_set_server  = utf8
collation_server      = utf8_general_ci
This is the associated launchpad bug report: https://bugs.launchpad.net/ubuntu/+source/mysql-5.5/+bug/958120.
Or easily run:
# Miraz added dpkg-reconfigure
dpkg-reconfigure mysql-server-5.5
But make sure there's no old mysql version installation installed, if there was please remove:
# Miraz quick mysql package check
dpkg -l *mysql*
Tom
  • 5,077
10
Innodb has a default setting (innodb_buffer_pool_size) which is set to 128M - this may be too large for your server (especially if you're using a small Amazon EC2 AMI - which I was) The fix that worked for me was to add the following line to /etc/mysql/my.cnf
innodb_buffer_pool_size = 16M
I wrote about this fix over here http://www.mlynn.org/2012/07/mysql-5-5-on-ubuntu-12-04-job-failed-to-start
10
I had a similar problem. It was frustrating because I couldn't see any error logs indicating what the problem was.
In my case, the value I had set for innodb_buffer_pool_size was too large for the memory of the server.
I found this out by running mysqld directly as the mysql user.
# su mysql
# mysqld
This way you actually see the error output.
Joel
  • 201
I also had a similar problem. The items below say they have been removed from mysql server 5.5.
If you have them in your my.cnf, it won't start. Comment them out with #.
(Info derived from : http://dev.mysql.com/doc/refman/5.5/en/replication-options-slave.html)
The options affected are shown in this list:
 --master-host
 --master-user
 --master-password
 --master-port
 --master-connect-retry
 --master-ssl
 --master-ssl-ca
 --master-ssl-capath
 --master-ssl-cert
 --master-ssl-cipher
 --master-ssl-key
belacqua
  • 23,540
It seems to boil down to errors in the MySQL configuration, located in /etc/mysql/my.cnf and files in /etc/mysql/conf.d/.
In my case it was a wrong bind-address value, because the IP address of my machine had changed and MySQL couldn't bind anymore. Feel free to rea more on this in this blog article.
gertvdijk
  • 69,427
boteeka
  • 61
A good way to debug the failures in the post-start process (/etc/init/mysql.conf) is to check the upstart logs:
sudo tail -f /var/log/upstart/mysql.log
That gave me a socket error:
error: 'Can't connect to local MySQL server through socket
In my case it was caused by a missing user setting under the [mysqld] group in my.cnf
prusswan
  • 1,049
I had the same issue. It turned out to be the mysql my.cnf master slave replications. Check your /var/log/mysql/error.log.
I hope that's a little help. Check the mysql settings first before you waste two hours with apparmor which just works fine.
Eliah Kagan
  • 119,640
When I had a similar MySQL error ("Job failed to start") after upgrading from 11.10 to 12.04, comment #27 on https://bugs.launchpad.net/ubuntu/+source/mysql-dfsg-5.1/+bug/573318?comments=all worked perfectly for me. Quote:
The problem for me was that the file /etc/apparmor.d/local/usr.sbin.mysqld did not exist after the upgrade. I manually copied one from one of the empty ones (i.e. only had header comment) and then everything was good to go.
For me the solution was to remove the line ...
set-variable = max_connections=200
... which is MySQL 3.x syntax and needs to be changed to
max_connections=200
Jorge Castro
  • 73,717
Ken West
I had the same issues, for me the bind-address was set improperly in my /etc/mysql/my.cnf file. So it seems anything that isn't right in the my.cnf can cause this issue. I haven't found anything in the logs that indicated this as the issue.
CLo
  • 111
My problem was 0% of free space! Double check :-)
moamahi
Check the /tmp permissions. I had this problem, after many time googleing and restarts, i found out that /tmp permissions was 755.
I change it to 777 and mysql start well.
shgnInc
  • 4,431
After an automatic update to mysqld-5.5.53 ubuntu 14.04.1, mysql would not start. These lines showed up in my syslog:
Oct 27 06:05:51 hostname kernel: [  593.168925] init: mysql post-start process (4997) terminated with status 1
Oct 27 06:05:51 hostname kernel: [  593.178241] type=1400 audit(1477562751.231:31): apparmor="STATUS" operation="profile_replace" profile="unconfined" name
Oct 27 06:05:51 hostname kernel: [  593.204392] init: mysql main process (5032) terminated with status 1
Oct 27 06:05:51 hostname kernel: [  593.204404] init: mysql respawning too fast, stopped
The problem was solved by creating this directory:
sudo mkdir /var/lib/mysql-files
sudo chmod 700 /var/lib/mysql-files
sudo chown mysql:mysql /var/lib/mysql-files
sudo /etc/init.d/mysql start
Yapsr
Just updated MySQL and AppArmor version as suggested here to fix this problem on Ubuntu 12.04 running on Amazon ec2 instance. I still get the error a few time but MySQL restarts itself automatically.
Kazark
  • 698
I had the same error messages, but the cause was different. My InnoDB tables were corrupt, because the whole file system went into read-only mode. I fixed the corruption by adding the following line to /etc/mysql/my.cf
innodb_force_recovery = 1
I started MySQL:
sudo service mysql start
MySQL did start and I dumped/exported all tables. I changed the innodb_force_recovery to 0 (=default) and restarted MySQL:
I'm using Ubuntu 12.04 with MySQL 5.5. It took a long time before I found the problem and I hope I can help someone with this answer. See also http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html
Coanda
  • 232
In my case the problem was the /etc/mysql/my.cnf file permission.
I changed it for cenvenience but it caused erros like
kernel: [604528.290448] type=1400 audit(1424350956.727:193): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/mysqld" pid=15008 comm="apparmor_parser"
The my.cnf permission was 766 and I changed it to 744 and two of three errors went away. There is still one similar error message but it did not prevent mysql from starting.
Hope this helps...
In my case, I had a wrong bind-address declaration. I ran ifconfig to discover the EC2's private IP address and updated it in the /etc/mysql/my.cnf file.
Ralph
  • 111
In my case i found a permission problem on /tmp. I just setted the tmp's directory permission to 766 and restart mysql service. Fixed out.
