I am trying to install Ubuntu 12.04 by creating a USB Boot Disk. I am using a 500 GB External Hard-drive ("Elements"). I get through the first part of using the start-up disk creator. I select Ubuntu 12.04 "Precise Pangolin" as the ISO, and my external hard-drive, which has 150 GB free, as the disc to use. I hit "Make Startup Disc". It asks me for authentication before I can copy files, and that part works. Then after copying files, it asks for authentication again to install the boot loader. At this point, it immediately says "Failed to install the bootloader." Any idea why I am having a problem?
I know with Ubuntu Quantal (12.10) usb-creator-gtk is currently plagued with Bug 915626. But your using 12.04
My recommendation would be to start fresh. Open the 'Disks' manager and format your usb drive and delete the current partition. Then recreate a New FAT32 partition and format.
After that is complete try the usb-creator again, see if you make any headway. If it still fails might I suggest a workaround.
In the Software Center look for a program called, "UnetBootin"
Install it and simply select the "Diskimage" bullet. Make sure the 2nd dropdown says "ISO" and press the button to select the ISO you wish to burn onto your disk.
Make sure that your USB Drive is selected under "Type" and the Drive is properly set to /dev/sdb1/ (Assuming your usb disk is /dev/sdb)
Let me know how that turns out!
- 981
Check your partition format . If it was NTFS ,then try to reformat to FAT32 and make your startup live usb again using Startup Disc Creator.
- 69
I had a very similar problem and solved it by using another usb-maker.
First I was using the KDE default usb-maker on Kubuntu 14.04 and flashed my stick a few times with different live images. Then "something" went not correctly somehow and my pc could not write the bootloader. So I tried
- another image that worked before
- compared the sd5 checksum, to see if the image was damaged
- tried to copy data on the stick an read it from there to check the stick
- tried to format it and place the partition few GB to the "right" (maybe the chips at the beginning were damaged, I have no idea)...
...same problem everytime at about 54% "couldn't install bootloader".
At the end I was booting from linux-mint 17 and used the default usb-maker from there. Everything worked fine.
So maybe you try unetbootin or also from another distro.
- 226
I got the same message.
Apparently it has something to do with permissions. Without even taking the USB out I
opened a command prompt and did
sudo -i
then did
usb-creator-kde
It installed without complaint.
- 13,475
I have had a similar problem using ubuntu 14.04. Everything seems to work fine until the end where it says "Failed to install bootloader" Although this certainly seems to be an issue, the bootable media still seems to work fine, even after receiving this message. Did you still try booting into the usb stick after receiving the message? In your bios you should have it set to boot into usb if connected, or go to your temporary boot menu (usually esc or f12 while booting) If it still does work it could simply be the specific distro you are installing. Sometimes Xubuntu seems to work better on older computers - especially Dells.
- 477
