I was previously an elementary os 5.1. I want to know how to do it so I can use Ubuntu. Ideally not by installing ubuntu via burning dvd and usb.
(Original title translates to: Removing the base os to make it ubuntu)
-- translated online from
Original Title: Menghapus os dasar agar menjadi ubuntu
Saya sebelum nya pengguna elementary os 5.1. Saya ingin mengetahui bagaimana cara nya agar saya bisa menggunakan ubuntu tetapi dengan tidak menginstall ubuntu melalui pembakaran dvd dan usb.
Mrusdi
I have a laptop with dead USB ports (old thinkpad t42p) that I use in QA-testing Ubuntu flavors.
I download the daily ISOs onto the local HDD to a location I selected.
The following entries were then added to /etc/grub.d/40_custom (this is a snippet only as it lists many other ISO options)
menuentry "Lubuntu QA testing 18.04.4 ISO noPAE" {
    set root=(hd0,7)
    set isofile="/lubuntu-18.04.4-desktop-i386.iso"
        loopback loop (hd0,7)/lubuntu-18.04.4-desktop-i386.iso
        linux (loop)/casper/vmlinuz boot=casper iso-scan/filename=/lubuntu-18.04.4-desktop-i386.iso forcepae --forcepae --
        initrd (loop)/casper/initrd
menuentry "Lubuntu QA testing 18.04.5 ISO noPAE" {
    set root=(hd0,7)
    set isofile="/lubuntu-18.04.5-desktop-i386.iso"
        loopback loop (hd0,7)/lubuntu-18.04.5-desktop-i386.iso
        linux (loop)/casper/vmlinuz boot=casper iso-scan/filename=/lubuntu-18.04.5-desktop-i386.iso forcepae --focepae  --
menuentry "Xubuntu QA testing 18.04.5 ISO noPAE" {
    set root=(hd0,7)
    set isofile="/xubuntu-18.04.5-desktop-i386.iso"
        loopback loop (hd0,7)/xubuntu-18.04.5-desktop-i386.iso
        linux (loop)/casper/vmlinuz boot=casper iso-scan/filename=/xubuntu-18.04.5-desktop-i386.iso forcepae --focepae  --
Note: The 'forcepae --forcepae' is required only because this really old pentium M device requires those kernel lines to boot. It's actually handy, as on other (prehistoric pentium) devices I have to manually type that detail onto the kernel line for the laptops with working thumb-drives on each QA-test boot.
You'll have to change the ISO files to match your system, plus location of where you stored the ISO files. Mine were in / of sda7. This is intended as example only.
To re-create the grub file use the command sudo update-grub.
guiverc
  • 33,561
