When I connect with ubuntu gnome x2goclient to a x2goserver running ubuntu xfce, I am unable to resume a suspended session after a short time (+-5 minutes). I've run debug both on client and server to try and look for anything, but no error messages. The display on the client just freezes; the server seems to say it has been succesfully resumed. But the screen is unresponsive. If I terminate, and start a new session, everything works. But then 5 minutes later (after inactivity) the same problem occurs.
After a short period the client then says "no response received from remote server".
The issue does not occur on x2goclient running windows, there the session can be continued later.
Client debug (only relevant parts, cannot post everything here)
x2go-DEBUG-../src/sshmasterconnection.cpp:356> Creating new channel for reverse tunnel 57307
x2go-DEBUG-../src/sshmasterconnection.cpp:368> Connecting to "127.0.0.1":4713
x2go-DEBUG-../src/sshmasterconnection.cpp:392> New channel created
x2go-DEBUG-../src/onmainwindow.cpp:6618> Proxy wrote on stderr: "Warning: No data received from remote proxy within 30 seconds.\n"
Server info
Sep 3 06:59:38 lnz1-inno /usr/bin/x2goumount-session[1567193]: x2goumount-session has been called with options: j.oosterhuis-50-1599113954_stDXFCE_dp24
Sep 3 06:59:38 lnz1-inno /usr/bin/x2goumount-session[1567193]: SSHFS share already unmounted, taking care of further clean-up (C-j.oosterhuis-50-1599113954_stDXFCE_dp24)
Sep 3 06:59:38 lnz1-inno /usr/bin/x2gofeature: x2gofeature called with options: X2GO_FMBINDINGS
Sep 3 06:59:38 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-extensions.features: x2goserver-extensions.features called with options: X2GO_FMBINDINGS
Sep 3 06:59:38 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver.features: x2goserver.features called with options: X2GO_FMBINDINGS
Sep 3 06:59:38 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-fmbindings.features: x2goserver-fmbindings.features called with options: X2GO_FMBINDINGS
Sep 3 07:00:12 lnz1-inno /usr/bin/x2goresume-session: x2goresume-session called with options: j.oosterhuis-50-1599113954_stDXFCE_dp24 800x600 adsl 16m-jpeg-9 us pc105/us 0 both no
Sep 3 07:00:12 lnz1-inno /usr/bin/x2gofeature: x2gofeature called with options: X2GO_RUN_EXTENSIONS
Sep 3 07:00:12 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-extensions.features: x2goserver-extensions.features called with options: X2GO_RUN_EXTENSIONS
Sep 3 07:00:12 lnz1-inno /usr/bin/x2goserver-run-extensions: x2goserver-run-extensions called with options: j.oosterhuis-50-1599113954_stDXFCE_dp24 pre-resume
Sep 3 07:00:13 lnz1-inno /usr/bin/x2goresume-session: client 192.168.23.106 has successfully resumed session with ID j.oosterhuis-50-1599113954_stDXFCE_dp24
Sep 3 07:00:13 lnz1-inno /usr/bin/x2gofeature: x2gofeature called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-extensions.features: x2goserver-extensions.features called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver.features: x2goserver.features called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-fmbindings.features: x2goserver-fmbindings.features called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-printing.features: x2goserver-printing.features called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-x2goagent.features: x2goserver-x2goagent.features called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-xsession.features: x2goserver-xsession.features called with options: X2GO_DESKTOPSHARING
Sep 3 07:00:13 lnz1-inno /usr/bin/x2gofeature: x2gofeature called with options: X2GO_RUN_EXTENSIONS
Sep 3 07:00:13 lnz1-inno /usr/share/x2go/x2gofeature.d/x2goserver-extensions.features: x2goserver-extensions.features called with options: X2GO_RUN_EXTENSIONS
Sep 3 07:00:13 lnz1-inno /usr/bin/x2goserver-run-extensions: x2goserver-run-extensions called with options: j.oosterhuis-50-1599113954_stDXFCE_dp24 post-resume
Sep 3 07:00:15 lnz1-inno /usr/bin/x2gomountdirs[1568154]: x2gomountdirs has been called with options: dir j.oosterhuis-50-1599113954_stDXFCE_dp24 jacco /home/j.oosterhuis/.x2go/ssh/key.KozDcL /home/jacco/.x2go/S-j.oosterhuis-50-1599113954_stDXFCE_dp24/spool__PRINT_SPOOL___REVERSESSH_PORT__57308
Sep 3 07:00:16 lnz1-inno /usr/bin/x2gomountdirs[1568154]: successfully mounted jacco@127.0.0.1:57308/home/jacco/.x2go/S-j.oosterhuis-50-1599113954_stDXFCE_dp24/spool to /tmp/.x2go-j.oosterhuis/spool/C-j.oosterhuis-50-1599113954_stDXFCE_dp24
Which seems to say "succesfully mounted".
