As the title says, when on eduroam my internet connection drops after some time (usually after a couple of minutes when I have a lot of traffic, e.g. zoom meetings, when there is less traffic it might hold for an hour). The laptop stays connected to the wifi but no website is accessible and I also can't ping any DNS servers (though existing connections with e.g. Netflix sometimes still work). I don't have this issue on Windows.
The journalctl output while when this happens is
Sep 02 22:40:19 carlos-linux wpa_supplicant[1062]: wlo1: SME: Trying to authenticate with f0:9e:63:05:60:71 (SSID='eduroam' freq=2412 MHz)
Sep 02 22:40:19 carlos-linux kernel: wlo1: disconnect from AP 34:6f:90:34:24:8e for new auth to f0:9e:63:05:60:71
Sep 02 22:40:19 carlos-linux kernel: wlo1: authenticate with f0:9e:63:05:60:71
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.1322] device (wlo1): supplicant interface state: completed -> authenticating
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.1323] device (p2p-dev-wlo1): supplicant management interface state: completed -> authenticating
Sep 02 22:40:19 carlos-linux kernel: wlo1: send auth to f0:9e:63:05:60:71 (try 1/3)
Sep 02 22:40:19 carlos-linux wpa_supplicant[1062]: wlo1: Trying to associate with f0:9e:63:05:60:71 (SSID='eduroam' freq=2412 MHz)
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.1582] device (wlo1): supplicant interface state: authenticating -> associating
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.1582] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
Sep 02 22:40:19 carlos-linux kernel: wlo1: authenticated
Sep 02 22:40:19 carlos-linux kernel: wlo1: associate with f0:9e:63:05:60:71 (try 1/3)
Sep 02 22:40:19 carlos-linux kernel: wlo1: RX ReassocResp from f0:9e:63:05:60:71 (capab=0x421 status=17 aid=0)
Sep 02 22:40:19 carlos-linux kernel: wlo1: f0:9e:63:05:60:71 denied association (code=17)
Sep 02 22:40:19 carlos-linux wpa_supplicant[1062]: wlo1: CTRL-EVENT-ASSOC-REJECT bssid=f0:9e:63:05:60:71 status_code=17
Sep 02 22:40:19 carlos-linux wpa_supplicant[1062]: wlo1: SME: Deauth request to the driver failed
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.2197] device (wlo1): supplicant interface state: associating -> disconnected
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.2198] device (p2p-dev-wlo1): supplicant management interface state: associating -> disconnected
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.3201] device (wlo1): supplicant interface state: disconnected -> scanning
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.3202] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
Sep 02 22:40:19 carlos-linux wpa_supplicant[1062]: wlo1: SME: Trying to authenticate with 34:6f:90:34:24:8e (SSID='eduroam' freq=5240 MHz)
Sep 02 22:40:19 carlos-linux kernel: wlo1: authenticate with 34:6f:90:34:24:8e
Sep 02 22:40:19 carlos-linux kernel: wlo1: send auth to 34:6f:90:34:24:8e (try 1/3)
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.4885] device (wlo1): supplicant interface state: scanning -> authenticating
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.4886] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
Sep 02 22:40:19 carlos-linux wpa_supplicant[1062]: wlo1: Trying to associate with 34:6f:90:34:24:8e (SSID='eduroam' freq=5240 MHz)
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.5025] device (wlo1): supplicant interface state: authenticating -> associating
Sep 02 22:40:19 carlos-linux NetworkManager[1239]: <info>  [1599111619.5025] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
Sep 02 22:40:19 carlos-linux kernel: wlo1: associate with 34:6f:90:34:24:8e (try 1/3)
Sep 02 22:40:19 carlos-linux kernel: wlo1: RX AssocResp from 34:6f:90:34:24:8e (capab=0x101 status=30 aid=0)
Sep 02 22:40:19 carlos-linux kernel: wlo1: 34:6f:90:34:24:8e rejected association temporarily; comeback duration 1000 TU (1024 ms)
Sep 02 22:40:19 carlos-linux kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Sep 02 22:40:20 carlos-linux kernel: iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
Sep 02 22:40:20 carlos-linux kernel: wlo1: Connection to AP 34:6f:90:34:24:8e lost
Sep 02 22:40:20 carlos-linux kernel: wlo1: associate with 34:6f:90:34:24:8e (try 2/3)
Sep 02 22:40:20 carlos-linux kernel: wlo1: RX AssocResp from 34:6f:90:34:24:8e (capab=0x101 status=30 aid=0)
Sep 02 22:40:20 carlos-linux kernel: wlo1: 34:6f:90:34:24:8e rejected association temporarily; comeback duration 1000 TU (1024 ms)
Sep 02 22:40:20 carlos-linux kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Sep 02 22:40:21 carlos-linux kernel: iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
Sep 02 22:40:21 carlos-linux kernel: wlo1: Connection to AP 34:6f:90:34:24:8e lost
Sep 02 22:40:21 carlos-linux kernel: wlo1: associate with 34:6f:90:34:24:8e (try 3/3)
Sep 02 22:40:21 carlos-linux kernel: wlo1: RX AssocResp from 34:6f:90:34:24:8e (capab=0x1101 status=17 aid=0)
Sep 02 22:40:21 carlos-linux kernel: wlo1: 34:6f:90:34:24:8e denied association (code=17)
Sep 02 22:40:21 carlos-linux wpa_supplicant[1062]: wlo1: CTRL-EVENT-ASSOC-REJECT bssid=34:6f:90:34:24:8e status_code=17
Sep 02 22:40:21 carlos-linux wpa_supplicant[1062]: wlo1: SME: Deauth request to the driver failed
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.6374] device (wlo1): supplicant interface state: associating -> disconnected
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.6374] device (p2p-dev-wlo1): supplicant management interface state: associating -> disconnected
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.7377] device (wlo1): supplicant interface state: disconnected -> scanning
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.7378] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
Sep 02 22:40:21 carlos-linux wpa_supplicant[1062]: wlo1: SME: Trying to authenticate with 34:6f:90:34:24:81 (SSID='eduroam' freq=2462 MHz)
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.8833] device (wlo1): supplicant interface state: scanning -> authenticating
Sep 02 22:40:21 carlos-linux kernel: wlo1: authenticate with 34:6f:90:34:24:81
Sep 02 22:40:21 carlos-linux kernel: wlo1: send auth to 34:6f:90:34:24:81 (try 1/3)
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.8834] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
Sep 02 22:40:21 carlos-linux wpa_supplicant[1062]: wlo1: Trying to associate with 34:6f:90:34:24:81 (SSID='eduroam' freq=2462 MHz)
Sep 02 22:40:21 carlos-linux NetworkManager[1239]: <info>  [1599111621.9074] device (wlo1): supplicant interface state: authenticating -> associating
Sep 02 22:40:21 carlos-linux kernel: wlo1: authenticated
This is the same issue as described here, but the fix there does not work for me. I guess that's because my Ubuntu networking config is different from their Arch config, so if anyone can tell me what to change in my config to make it match Arch's ("default") config, I would also appreciate that.
Edit: The problem is caused by switching APs so fixing the BSSID for the network in Gnome's config fixes the disconnects, but this probably not optimal...
Edit 2: It seems that my wifi adapter is being recognized as Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter (201NGW) even though it's a intel AX201. I also found these lines in my dmesg:
[    4.382504] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-c0-hr-b0-56.ucode failed with error -2
[    4.387696] iwlwifi 0000:00:14.3: loaded firmware version 55.d9698065.0 Qu-c0-hr-b0-55.ucode op_mode iwlmvm
[    4.387716] iwlwifi 0000:00:14.3: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Does this mean that the wrong firmware is being loaded for the device?
Diagnostics:
  • When this happens mtr says "no route to host"
  • pgrep -a dh gives two entries:
995171 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/NetworkManager/dhclient-wlo1.pid -lf /var/lib/NetworkManager/dhclient-85e18157-cc78-4948-a5fb-300853e6bb8b-wlo1.lease -cf /var/lib/NetworkManager/dhclient-wlo1.conf wlo1
995228 /sbin/dhclient -d -q -6 -S -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/NetworkManager/dhclient6-wlo1.pid -lf /var/lib/NetworkManager/dhclient6-85e18157-cc78-4948-a5fb-300853e6bb8b-wlo1.lease -cf /var/lib/NetworkManager/dhclient6-wlo1.conf wlo1
0x539
  • 278
I found a solution online that seems to have worked, at least for me:
https://bbs.archlinux.org/viewtopic.php?id=230963&p=2
I followed nstarclix's procedure and removed some steps which were not possible in Ubuntu. Here's what worked for me:
First, modify the file /etc/NetworkManager/NetworkManager.conf and add the following lines:
[main]
dhcp=dhclient
(Also, make sure you have dhclient installed, I believe it's an Ubuntu default)
Then check the file /etc/resolv.conf, you should have the name server set to 127.0.0.53, it seems to be the default
Then the following commands:
sudo systemctl enable systemd-resolved.service
sudo systemctl disable systemd-networkd.service
Now reboot and hopefully everything will work, although I haven't tried this solution for a long period of time just yet.
Forgive the necrobump. After trawling and trying various things for the hp elitebook 640 g9 on ubuntu, the fix looks to have been updating the BIOS.
(eduroam kept dropping issue)
