I recently installed Ubuntu 20.04 to be able to dual boot with my existing Windows 10. After the install I wanted to go back to Windows 10, but there is no GRUB menu that prompts me to pick which OS I to boot. It just goes straight to Ubuntu 20.04. After going into my UEFI and trying to boot Windows 10 from there, I get a boot order error and it sends me back to Ubuntu.
It may have something to do with Windows 10 is in Legacy mode according to the results of Boot-Repair that I ran in Ubuntu.
The boot of your PC is in UEFI mode.
You may want to retry after changing it to BIOS-compatibility/CSM/Legacy mode.
This is the link I got for the boot repair: https://paste.ubuntu.com/p/MqNQz5992n/.
============================== Boot Info Summary ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/nvme0n1 and looks at sector 908892160 of the same hard drive for core.img. core.img is at this location and looks for (,gpt1)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_gpt biosdisk
nvme0n1p1: _____________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 20.04.1 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
                   /boot/grub/i386-pc/core.img
nvme0n1p2: _____________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
nvme0n1p3: _____________________________________________________________________
File system:       ntfs
Boot sector type:  Windows 8/2012: NTFS
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:  Windows 8 or 10
Boot files:        /Windows/System32/winload.exe
nvme0n1p4: _____________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
nvme0n1p5: _____________________________________________________________________
File system:       ntfs
Operating System:
Boot files:        /bootmgr /Boot/BCD
nvme0n1p6: _____________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
nvme0n1p7: _____________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Operating System:
Boot files:        /efi/BOOT/fbx64.efi /efi/BOOT/mmx64.efi
                   /efi/ubuntu/grubx64.efi /efi/ubuntu/mmx64.efi
                   /efi/ubuntu/shimx64.efi /efi/ubuntu/grub.cfg
nvme0n1p8: _____________________________________________________________________
File system:       BIOS Boot partition
Boot sector type:  Grub2's core.img
Boot sector info:
================================ 2 OS detected =================================
OS#1: The OS now in use - Ubuntu 20.04.1 LTS CurrentSession on nvme0n1p1 OS#2: Windows 8 or 10 on nvme0n1p3
============================ Architecture/Host Info ============================
CPU architecture: 64-bit BOOT_IMAGE of the installed session in use: /boot/vmlinuz-5.4.0-45-generic root=UUID=231ffef0-7328-48de-b30e-63d4f4116b9d ro quiet splash DEEPIN_GFXMODE= vt.handoff=7
===================================== UEFI =====================================
BIOS is EFI-compatible, and is setup in EFI-mode for this installed-session. SecureBoot enabled.
efibootmgr -v BootCurrent: 0001 Timeout: 0 seconds BootOrder: 0001,0002,9999,0000 Boot0000 Windows Boot Manager HD(1,GPT,eb5eca17-c790-4a10-a3e1-9049db782e3e,0x800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}.................... Boot0001* ubuntu HD(7,GPT,9e58818b-ea10-d946-9936-b648c7eabb9b,0x361cf000,0xfa800)/File(\EFI\ubuntu\shimx64.efi) Boot0002* Solid State Disk PciRoot(0x0)/Pci(0x1d,0x0)/Pci(0x0,0x0)/NVMe(0x1,00-25-38-84-81-BA-3A-27)/HD(7,GPT,9e58818b-ea10-d946-9936-b648c7eabb9b,0x361cf000,0xfa800)..BO Boot9999* USB Drive (UEFI) PciRoot(0x0)/Pci(0x1d,0x0)/USB(16,0)..BO
4d5de9b92e5f3729724c60ce0541cb49 nvme0n1p5/Boot/bootx64.efi bed45d1c9554cea09924d3814cb7c446 nvme0n1p7/BOOT/fbx64.efi 4487628005555bfd4a4c0a47211e0700 nvme0n1p7/BOOT/mmx64.efi 04cd9cb6ceccbde1ca100ed1cae0f429 nvme0n1p7/ubuntu/grubx64.efi 4487628005555bfd4a4c0a47211e0700 nvme0n1p7/ubuntu/mmx64.efi f7a57b08bc7c1c85417ae4cea582d1d4 nvme0n1p7/ubuntu/shimx64.efi f7a57b08bc7c1c85417ae4cea582d1d4 nvme0n1p7/BOOT/BOOTX64.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, hasBIOSboot, has-noESP, not-usb, not-mmc, has-os, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p1 : is-os, 64, apt-get, grub-pc , grub2, grub-install, grubenv-ok, update-grub, farbios nvme0n1p3 : is-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios nvme0n1p4 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios nvme0n1p5 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios nvme0n1p7 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
Partitions info (2/3): _________________________________________________________
nvme0n1p1 : isnotESP, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot nvme0n1p3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot nvme0n1p4 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot nvme0n1p5 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, bootmgr, is-winboot nvme0n1p7 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
nvme0n1p1 : not-sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, nvme0n1 nvme0n1p3 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1 nvme0n1p4 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1 nvme0n1p5 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1 nvme0n1p7 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 476.96 GiB, 512110190592 bytes, 1000215216 sectors Disk identifier: 81B593F5-464F-48C9-A1AF-4785F23519FB Start End Sectors Size Type nvme0n1p1 806489414 888410111 81920698 39.1G Linux filesystem nvme0n1p2 534528 567295 32768 16M Microsoft reserved nvme0n1p3 567296 806489413 805922118 384.3G Microsoft basic data nvme0n1p4 970330112 973905919 3575808 1.7G Windows recovery environment nvme0n1p5 973905920 1000202239 26296320 12.6G Microsoft basic data nvme0n1p6 888410112 907866111 19456000 9.3G Linux swap nvme0n1p7 907866112 908892159 1026048 501M Microsoft basic data nvme0n1p8 908892160 908894207 2048 1M BIOS boot Partition table entries are not in disk order.
parted -lm (filtered): _________________________________________________________
nvme0n1:512GB:nvme:512:512:gpt:SAMSUNG MZVLB512HAJQ-000H1:; 2:274MB:290MB:16.8MB::Microsoft reserved partition:msftres; 3:290MB:413GB:413GB:ntfs:Basic data partition:msftdata; 1:413GB:455GB:41.9GB:ext4::; 6:455GB:465GB:9961MB:linux-swap(v1)::swap; 7:465GB:465GB:525MB:fat32::msftdata; 8:465GB:465GB:1049kB:::bios_grub; 4:497GB:499GB:1831MB:ntfs::hidden, diag; 5:499GB:512GB:13.5GB:ntfs:Basic data partition:hidden, msftdata;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL nvme0n1
├─nvme0n1p1 ext4 231ffef0-7328-48de-b30e-63d4f4116b9d 28623785-44c4-5c4e-aa69-f8e5a9415e57
├─nvme0n1p2 5ff1f579-038f-4385-9be1-d423787404fa Microsoft reserved partition ├─nvme0n1p3 ntfs 1CF8413BF8411504 221d78af-4c8a-4b4c-90a1-281c6602731b Windows Basic data partition ├─nvme0n1p4 ntfs 2C5CC6215CC5E624 a324444e-e255-40cb-9c74-c849d9487f65
├─nvme0n1p5 ntfs B84CBFDD4CBF949A e7c6a971-9935-4fba-ade0-5be613e70550 RECOVERY Basic data partition ├─nvme0n1p6 swap 95f4887e-4757-4638-a4ff-d6f577bd13d7 c00d0051-28ea-cf47-9912-7308c6b7cea8
├─nvme0n1p7 vfat BF47-D8C9 9e58818b-ea10-d946-9936-b648c7eabb9b
└─nvme0n1p8 3f0c5f86-a011-495e-a721-b72779ed22f5
df (filtered): _________________________________________________________________
       Avail Use% Mounted on
nvme0n1p1 25.8G 27% / nvme0n1p3 235.2G 39% /media/lua/Windows nvme0n1p4 898.3M 49% /mnt/boot-sav/nvme0n1p4 nvme0n1p5 1.5G 88% /mnt/boot-sav/nvme0n1p5 nvme0n1p7 492.2M 2% /mnt/boot-sav/nvme0n1p7
Mount options: __________________________________________________________________
nvme0n1p1 rw,relatime nvme0n1p3 ro,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 nvme0n1p4 ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096 nvme0n1p5 ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096 nvme0n1p7 rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
=================== nvme0n1p1/boot/grub/grub.cfg (filtered) ====================
Ubuntu 231ffef0-7328-48de-b30e-63d4f4116b9d Ubuntu, with Linux 5.4.0-45-generic 231ffef0-7328-48de-b30e-63d4f4116b9d Ubuntu, with Linux 5.4.0-42-generic 231ffef0-7328-48de-b30e-63d4f4116b9d
END /etc/grub.d/30_os-prober
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
======================== nvme0n1p1/etc/fstab (filtered) ========================
<file system> <mount point> <type> <options> <dump> <pass>
UUID=231ffef0-7328-48de-b30e-63d4f4116b9d / ext4 defaults 0 1 UUID=95f4887e-4757-4638-a4ff-d6f577bd13d7 swap swap defaults 0 2
==================== nvme0n1p1/etc/default/grub (filtered) =====================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
================= nvme0n1p1: Location of files loaded by Grub ==================
       GiB - GB             File                                 Fragment(s)
399.032908440 = 428.458322944 boot/grub/grub.cfg 3 420.825877190 = 451.858344960 boot/grub/i386-pc/core.img 1 389.871863365 = 418.621725696 boot/vmlinuz 1 386.481230736 = 414.981061632 boot/vmlinuz-5.4.0-42-generic 1 389.871863365 = 418.621725696 boot/vmlinuz-5.4.0-45-generic 1 386.481230736 = 414.981061632 boot/vmlinuz.old 1 384.970366478 = 413.358783488 boot/initrd.img 4 390.089079857 = 418.854960128 boot/initrd.img-5.4.0-42-generic 2 384.970366478 = 413.358783488 boot/initrd.img-5.4.0-45-generic 4 390.089079857 = 418.854960128 boot/initrd.img.old 2
=================== nvme0n1p1: ls -l /etc/grub.d/ (filtered) ===================
-rwxr-xr-x 1 root root 17622 Aug 17 07:04 10_linux -rwxr-xr-x 1 root root 42359 Aug 17 07:04 10_linux_zfs -rwxr-xr-x 1 root root 12894 Aug 17 07:04 20_linux_xen -rwxr-xr-x 1 root root 12059 Aug 17 07:04 30_os-prober -rwxr-xr-x 1 root root 1424 Aug 17 07:04 30_uefi-firmware -rwxr-xr-x 1 root root 214 Aug 17 07:04 40_custom -rwxr-xr-x 1 root root 216 Aug 17 07:04 41_custom
=================== nvme0n1p7/efi/ubuntu/grub.cfg (filtered) ===================
search.fs_uuid 231ffef0-7328-48de-b30e-63d4f4116b9d root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg
=============================== StdErr Messages ================================
File descriptor 63 (pipe:[88315]) leaked on lvs invocation. Parent PID 31791: /bin/bash
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would reinstall the grub2 of nvme0n1p1 into the MBR of nvme0n1. Additional repair would be performed: unhide-bootmenu-10s win-legacy-basic-fix
Blockers in case of suggested repair: __________________________________________
LegacyWindows detected. Please enable BIOS-compatibility/CSM/Legacy mode in your UEFI firmware, and use this software from a live-CD (or live-USB).
Final advice in case of suggested repair: ______________________________________
The boot of your PC is in UEFI mode. You may want to retry after changing it to BIOS-compatibility/CSM/Legacy mode.
karel
  • 122,292
  • 133
  • 301
  • 332
