-1
I'm on a fresh installation of Ubuntu and planning to install i3wm. Unfortunately, the brightness is completely stuck on the maximum, rendering it basically torture to use during the night. Neither the brightness keys on my keyboard nor the brightness slider on the top right dropdown do anything. The brightness keys do show that the brightness is decreasing on the slider but it doesn't actually change at all. Please help! I'm using a Lenovo Flex 5 14.
Edit: It's definitely not the laptop itself's problem because the brightness buttons worked when I was on Windows and when I shut down the computer, the space around the Shut Down prompt is darker.
Try changing it with xrandr
xrandr --output <display> --brightness <value between 0 and 1>
If you are unsure about the display name just press tab once you get to it.
For example I would use:
xrandr --output eDP-1-1 --brightness .5
You can try to use xbacklight
Or you could try the application brightness-controller . See the Github page or install with
sudo add-apt-repository ppa:apandada1/brightness-controller
sudo apt update
sudo apt install brightness-controller
Fixed it! Turns out this is an issue with my laptop's APU, the 4500u. I had to update the kernel to 5.8 and then boot without Secure Boot in the BIOS.
