After reading this post, I've followed this answer. But , when I edit the /etc/netplan/01-netcfg.yaml, it was blank. So I create that file and add optional: true. After sudo netplan apply, It turns out to be an error error in network definition unknown key 'optional'.
Is the previous post answer still relevant for ubuntu 20.04? And he stated that:
Don't mask or disable the systemd service.
So, what is the best solution for this in 20.04?
edit:
result of ls /etc/netplan
00-installer-config.yaml  01-netcfg.yaml
result of cat /etc/netplan/01-netcfg.yaml
optional: true
result of sudo lshw -C network as @heynnema requested as @heynnema requested and result of cat /etc/netplan/*.yaml
In /etc/netplan:
sudo rm -i /etc/netplan/01-netcfg.yaml # remove unnecessary file
sudo -H gedit /etc/netplan/00-installer-config.yaml # edit this file with these contents:
For dhcp:
network:
  version: 2
  renderer: networkd
  ethernets:
    enp0s3:
      dhcp4: true
      optional: true
For static IP: (bridged network)
network:
  version: 2
  renderer: networkd
  ethernets:
    enp0s3:
      addresses:
        - 192.168.x.xxx/24
      gateway4: 192.168.x.1
      nameservers:
        search: [mydomain, otherdomain]
        addresses: [8.8.8.8, 8.8.4.4]
      optional: true
Create /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg
sudo -H gedit /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg
with the following content:
network: {config: disabled}
Then:
sudo netplan generate
sudo netplan apply
reboot
heynnema
  • 73,649
