I was trying to configure my fan speeds and the process went fairly normal the first time. (Instructions here) I must have messed up somewhere along the way, and now when I try to restart the process I get this kind of message:
# pwmconfig version 3.6.0
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
Found the following devices:
hwmon0 is AC
hwmon1 is acpitz
hwmon2 is BAT0
hwmon3 is coretemp
hwmon4 is pch_skylake
hwmon5 is iwlwifi_1
hwmon6 is dell_smm
Found the following PWM controls:
hwmon6/pwm1 current value: 0
Giving the fans some time to reach full speed...
Found the following fan sensors:
hwmon6/fan1_input current speed: 0 ... skipping!
There are no working fan sensors, all readings are 0.
Make sure you have a 3-wire fan connected.
You may also need to increase the fan divisors.
See doc/fan-divisors for more information.
The fan has reset to 0 RPM and I don't know how to get it back up to normal speed. If I go to sensors the RPM stays at 0, if I use xsensors I still don't get any higher RPM. I have tried to add a load to the CPU to check if the fan is simply not on because it has no load but the temps got up to 80 C before I quit the stress test. Is there a way to simply reset everything back to normal so that the fan will be configured as default? Please help, I am slightly scared for my computer and it would be unusable if I can't use the fan.
