A few hours ago my Canonical Livepatch stopped working. I searched for the solution and than decided to reinstall Canonical Livepatch. Now I am getting the following error:
Failed to enable Livepatch: cannot enable machine: cannot send request:
  Post https://livepatch.canonical.com/api/machine-tokens: EOF
I could not find anything online about this problem so I'm posting. Thanks for your time.
Zanna
  • 72,312
After a while i was able to find a solution, so to speak. Well, sorta. Nevertheless, it works like a charm in my particular situation.
1) sudo canonical-livepatch disable
2) sudo snap remove canonical-livepatch
3) sudo cp /etc/machine-id /etc/machine-id.original
4) sudo cp /var/lib/dbus/machine-id /var/lib/dbus/machine-id.original
5) gedit /etc/machine-id
(remove everything and save empty machine-id)
6) sudo systemd-machine-id-setup
reboot
7) sudo snap install canonical-livepatch
Now proceed to (https://auth.livepatch.canonical.com/) and obtain the token, then
8) sudo canonical-livepatch enable [your token]
Your livepatch should work from this point pretty stable and apply necessary updates.
Source: Canonical livepatch failed when I tried to enable token
