29
I don't know where to ask, so I am asking here. While having an online meeting, whenever I share my screen it always shows as a black screen with my cursor to other people in the meeting. It doesn't matter which platform I am using be it Skype, Google Meet, Zoom, or any other. In windows, there is no problem like this.
OS - UBUNTU 18.04
Graphics Card - NVIDIA GeForce GTX 1050 Ti
Please, Help me to resolve this problem.
6 Answers6
40
The default Ubuntu 18.04 Bionic Beaver installation comes with Wayland enabled. The objective is to disable Wayland and enable Xorg display server instead.
You might need to update GDM3 custom configuration file
/etc/gdm3/custom.conf
Uncommenting this will force the login screen to use Xorg.
#WaylandEnable=false
After making the changes, reboot the system and voila, it worked for me!
11
Read this article to know more about this problem. Actually, this problem happens because of the Wayland display server. The first answer is about changing Wayland(newer and more secure but not more stable than Xorg) back to Xorg. If you want to stay in Wayland this solution helps to fix the problem in chrome. Not for all desktop apps you have.
Mode Investigation
Check which session you are using with the command:
$ echo $XDG_SESSION_TYPE
wayland
There are some wrappers and tools to try to make it easy for an X11 app to move to Wayland, but it seems that nothing is perfect. And this is another case.
Solution for Chrome
At last, it seems that Chrome is doing the move to PipeWire, but not by default. It must be enabled as an experimental flag, with this in a tab address.Type this in address bar:
chrome://flags/#enable-webrtc-pipewire-capturer
Enable the experimental Feature and relaunch Chrome, now the connection works well. Now Chrome uses the system selection window for sharing the screen or a window. Also, Teams works well in Chrome over Wayland, and the black screen + mouse is now solved.
Fix #1:
  1. Install xcompmgr using your Linux distro's package manager.
sudo apt install xcompmgr
  1. After installing, open the terminal and run this command:
xcompmgr -c -l0 -t0 -r0 -o.00
  1. Open compton.conf
gedit ~/.config/compton.conf
  1. Edit the following line:
shadow-exclude = [ "name = 'cpt_frame_window' " ];
Fix #2: Run Ubuntu on Xorg instead of Wayland.
Ankit
  • 131
In KUbuntu 18.04+ none of the above solutions worked for me for the Zoom APP, neither the official solution written in Zoom support. I have a Nvidia 2080 GPU.
In order to fix it, I had to open the app "Compositor" in KDE menu and select the render engine to "XRender" instead of any of the OpenGL engines (v2.0, v3.1).
I had a problem like this which was screen related. Fixed it by going to the screen settings by pressing the on-screen menu button -> 'multi-window settings' -> 'multi-windows modes' and setting it to "off". Im not sure what this feature is for, but it seems like a side effect of it is to make a large black rectangle in the screen.
For Rocky Linux/Fedora/Red Hat - find file in
/etc/gdm/custom.conf
And uncomment - line -
#WaylandEnable=false to WaylandEnable=false
And Restart PC.
