I recently switched to Ubuntu, and I'm new to Linux. I want to play Minecraft on version 1.8.9 on my Ubuntu machine.
I heard that you need to set your java to version 8, so I did that, and now the result of java -version is:
marzeq@marzeq-Aspire-VX5-591G:~$ java -version
openjdk version "1.8.0_265"
OpenJDK Runtime Environment (build 1.8.0_265-8u265-b01-0ubuntu2~20.04-b01)
OpenJDK 64-Bit Server VM (build 25.265-b01, mixed mode)
as expected.
Also just for good measures I set the Java executable path in the Launcher to /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java.
But the game still crashes with the exit code 0.
The weirder thing is that the vanilla version won't even give a log, so I need to use the Forge Mod Loader to even see the log.
The log is so small that I can upload it here:
[10:01:32] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[10:01:32] [main/INFO]: Using primary tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[10:01:32] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLTweaker
[10:01:32] [main/INFO]: Forge Mod Loader version 11.15.1.1722 for Minecraft 1.8.9 loading
[10:01:32] [main/INFO]: Java is OpenJDK 64-Bit Server VM, version 1.8.0_265, running on Linux:amd64:5.4.0-42-generic, installed at /usr/lib/jvm/java-8-openjdk-amd64/jre
[10:01:32] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[10:01:32] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[10:01:32] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[10:01:32] [main/INFO]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[10:01:34] [main/INFO]: Found valid fingerprint for Minecraft. Certificate fingerprint cd99959656f753dc28d863b46769f7f8fbaefcfc
[10:01:34] [main/ERROR]: FML appears to be missing any signature data. This is not a good thing
[10:01:34] [main/INFO]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[10:01:34] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[10:01:34] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.TerminalTweaker
[10:01:34] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.TerminalTweaker
[10:01:34] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[10:01:34] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_265]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_265]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_265]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_265]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
Caused by: java.awt.AWTError: Assistive Technology not found: org.GNOME.Accessibility.AtkWrapper
at java.awt.Toolkit.loadAssistiveTechnologies(Toolkit.java:807) ~[?:1.8.0_265]
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:886) ~[?:1.8.0_265]
at org.lwjgl.LinuxSysImplementation.<clinit>(LinuxSysImplementation.java:50) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.createImplementation(Sys.java:131) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:116) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at net.minecraft.client.Minecraft.func_71386_F(Minecraft.java:2756) ~[ave.class:?]
at net.minecraft.client.main.Main.main(SourceFile:41) ~[Main.class:?]
... 6 more
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: net.minecraftforge.fml.relauncher.FMLSecurityManager$ExitTrappedException
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.fml.relauncher.FMLSecurityManager.checkPermission(FMLSecurityManager.java:30)
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at java.lang.SecurityManager.checkExit(SecurityManager.java:761)
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at java.lang.Runtime.exit(Runtime.java:107)
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at java.lang.System.exit(System.java:973)
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraft.launchwrapper.Launch.launch(Launch.java:138)
[10:01:34] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
Does anybody have any clue what's happening? I'll greatly appreciate the help!
