I was already on my way to reverting to a backup image of my MicroSD that was ~1.5 week old until after writing it to a brand new SanDisk Micro SD card, the ext4 filesystem gave a bunch of inode errors during boot time, everything in the OS was more or less totally broken and fsck gave basically an insane list of things that were broken on a filesystem level. It's a brand new Sandisk Micro SD card, but apparently during the backup process, data corruption slipped in through the back door.
I'm running Ubuntu 20.04 on a Raspberry Pi 4B, which means that it's running on arm64 architecture, so suggestions to download the .deb packages straight from kernel.org, or to install i.e. python3-minimal doesn't work, since there aren't any installation candidates for ARM64.
Solutions pointing to .deb and other installation packages that simply do not exist for arm64 architecture at all.
There was also plenty of outdated or downright bad advice altogether -- also, none of the system restore methods described in either the manuals or within Ubuntu's user community (boot CD on a Raspberry Pi?) don't apply to 20.04 on the Raspberry Pi 4B, at least not yet.
My install is still staggering along, but the apt/dpkg update system remains pretty much broken no matter what I try. I have unsuccessfully tried downloading the .deb packages and installing them separately.
As for this moment; Py3compile and Pyclean are not found anywhere and those two are the main culprits in dpkg/apt not working, so this answer doesn't work.
$ sudo apt install python3-all
Reading package lists... Done
Building dependency tree
python3-all is already the newest version (3.8.2-0ubuntu2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 0 B/129 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up pychess (0.12.2-1build1) ...
/var/lib/dpkg/info/pychess.postinst: 6: pycompile: not found
dpkg: error processing package pychess (--configure):
installed pychess package post-installation script subprocess returned error ex it status 127
dpkg: error processing package python-pkg-resources (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
Setting up gir1.2-dee-1.0 (1.2.7+17.10.20170616-4ubuntu6) ...
/var/lib/dpkg/info/gir1.2-dee-1.0.postinst: 6: pycompile: not found
dpkg: error processing package gir1.2-dee-1.0 (--configure):
installed gir1.2-dee-1.0 package post-installation script subprocess returned e rror exit status 127
Setting up python3-minimal (3.8.2-0ubuntu2) ...
Traceback (most recent call last):
File "/usr/bin/py3compile", line 28, in <module>
import struct
File "/usr/lib/python3.8/struct.py", line 13, in <module>
from _struct import *
ModuleNotFoundError: No module named '_struct'
dpkg: error processing package python3-minimal (--configure):
installed python3-minimal package post-installation script subprocess returned error exit status 1
No apport report written because MaxReports is reached already
Errors were encoun tered while processing:
pychess
gir1.2-dee-1.0
python3-minimal
needrestart is being skipped since dpkg has failed
- Reinstalling with
sudo apt install --reinstall -f python3-alldoes not help either.
$ sudo apt install --reinstall -f python3-all
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/131 kB of archives.
(Reading database ... 1052975 files and directories currently installed.)
Preparing to unpack .../python3-all_3.8.2-0ubuntu2_arm64.deb ...
Unpacking python3-all (3.8.2-0ubuntu2) over (3.8.2-0ubuntu2) ...
installed pychess package post-installation script subprocess returned error exit status 127
Setting up python3-all (3.8.2-0ubuntu2) ...
installed gir1.2-dee-1.0 package post-installation script subprocess returned error exit status 127
import struct
pychess
gir1.2-dee-1.0
python3-minimal
sudo dpkg --configure -aandsudo apt -f install, result in the same errors.- The dpkg recovery instructions (as for i.e. How to reinstall dpkg) don't work either since there aren't i.e. the required files at
/var/cache/apt/archives/.
I tried to get the .deb packages straight from Ubuntu's website, extract them and install them separately.
Given the fact that according to the forum posts that I've been going through, people have been breaking their Ubuntu and other Debian-based systems for at least the past ten years whenever something has gone haywire with Python - be it user error or a package breaking things, would it be a bit safer to somehow make a fundamental fix in the way the dpkg/apt architecture is handled in Linux and isolate whatever Python modules and dependencies they need to run from the rest of the operating system? Or to create some sort of a fail-safe system restore method in cases of these kinds of grievous situations which seem to be quite prevalent.
