I have just installed Ubuntu 20.4 LTS. I performed the installation without Wifi connection, as this lead to the installer becoming unresponsive. Yet without Wifi connection the installer went on just fine.
With the fresh-install, two issues have arisen.
  1. Opening the Ubuntu Software application prompts it becomes stuck while saying "Software catalog is being downloaded".
  2. When using the Software Updater, it gets stuck stating "Waiting for packagekitd to stop".
I tried stopping packagekitd with the following command:
systemctl stop packagekit
Then, after running the Software Updater again, it got stuck on "Downloading from security.ubuntu.com/ubuntu no.archive.ubuntu.com/ubuntu"
I am sure the "no." above comes from the fact that I am situated in Oslo.
Would anyone have any ideas for a beginner like me to look for solutions?
It seems I have to rely on the software updater in order to install programs (such as sublime-text), hence this is really stopping me from starting to use Linux at all. Any help would be appreciated.
Here is the output of sudo apt update:
Reading package lists... Done
E: Could not get lock /var/lib/apt/lists/lock. It is held by process 1489 (packagekitd)
N: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to lock directory /var/lib/apt/lists/
And the output of sudo apt upgrade:
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libdrm2:i386 libexpat1:i386 libglapi-mesa:i386 libglvnd0:i386
  libx11-xcb1:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386
  libxcb-present0:i386 libxcb-sync1:i386 libxdamage1:i386 libxfixes3:i386
  libxshmfence1:i386 libxxf86vm1:i386
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  apport apport-gtk bind9-dnsutils bind9-host bind9-libs ghostscript
  ghostscript-x gir1.2-javascriptcoregtk-4.0 gir1.2-webkit2-4.0 gnome-shell
  gnome-shell-common libcurl3-gnutls libgs9 libgs9-common
  libjavascriptcoregtk-4.0-18 libmysqlclient21 libnss3 libsane libsane-common
  libsmbclient libsnmp-base libsnmp35 libssh-4 libwbclient0
  libwebkit2gtk-4.0-37 libwhoopsie0 ppp python3-apport python3-problem-report
  python3-software-properties samba-libs sane-utils software-properties-common
  software-properties-gtk whoopsie
35 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 36,7 MB of archives.
After this operation, 175 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://security.ubuntu.com/ubuntu focal-security/main amd64 libssh-4 amd64 0.9.3-2ubuntu2.1 [170 kB]
Get:2 http://security.ubuntu.com/ubuntu focal-security/main amd64 libcurl3-gnutls amd64 7.68.0-1ubuntu2.2 [231 kB]
At this point the process is stuck showing 1% [2 libcurl3-gnutls 0 B/231 kB 0%]
Update:
I have now learned I can kill the process locking up sudo-update, and I have tried changing servers (in Software & Updates).
When I run sudo apt update, the following is produced
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://archive.ubuntu.com/ubuntu focal-backports InRelease [98,3 kB]
Get:3 http://archive.ubuntu.com/ubuntu focal-security InRelease [107 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease [111 kB]
Get:5 http://archive.ubuntu.com/ubuntu focal/main i386 Packages [718 kB]
13% [5 Packages 0 B/718 kB 0%]
..the updater gets stuck.
Zanna
  • 72,312
I found the answer. My problem was that I had an UTM firewall interrupting the connection to the security.ubuntu.com and archive.ubuntu.com (regardless of the server mirror). Using another Wifi network completely resolved the issue.
Thanks for the help.
Go to Show Applications and then seach for Software & Updates
In 20.04 the window you get when you click that has...
Download from: and then a dropdown menu to choose a different server.
Note that you might get another error due to a previously broken package but if so just post the error.
(Also note that you want Software & Updates NOT Software Updater but you can run that afterwards.)
