I can’t seem to access Grub on my HP Stream laptop (model 14-ds0033nr). Laptop came with windows 10, and I’m currently using Ubuntu 20.04 LTS as the sole OS.
My main issue is that I forgot my root password, and need access to Grub (I think..?) to change the password.
I’ve tried F1-F12, ESC, Shift, E,C following Post and nothing seems to work. I appreciate any help you guys can offer
Download 20.04 and write the ISO to USB. Boot to the USB. (You can usually select which to boot first by pressing F12, ESC, or sometimes F2 - it will vary depending on the computer you own as it's not a standardized key.)
Now, in the live environment, you're going to mount the disk.
mkdir /mnt/fix
mount /dev/sdXX /mnt/fix
sdXX is your hard drive - it's usually sda.
Next, you're going to chroot to temporarily mount it as root.
chroot /mnt/fix
The hard work is over. You just use passwd or passwd <user> follow it with exit (to get out of chroot) when you're done. Then, just unmount your disk with:
umount /mnt/fix
Reboot following the usual methods, being sure to remove the USB when prompted to do so. Your new password should be whatever you set it to.
KGIII
  • 4,101
Menu will appear if you press and hold Shift during loading Grub, if you boot using BIOS. When your system boots using UEFI, press Esc.
Ron
  • 255
