I installed Ubuntu 12.04 today on my Samsung RV509 Notebook (Nvidia Geforce 315M) and the backlight brightness controls don't work on it.
I did some digging around the web and found the samsung tools voria repository and installed Samsung-backlight package from there. This didn't help though.
I see that the Nvidia drivers are in use. Any help or pointers are appreciated.
Bruno Pereira
  • 74,715
Nands
  • 121
You may try this:
gksudo gedit /etc/default/grub
Find this line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
And change to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Save and close the file. Then update grub:
sudo update-grub
Reboot and check.
This did the trick for me on a Samsung NP300 notebook. The brightness keys in the keyboard were not working before this. Hope this helps.
Tom
  • 491
Run:
gksu gedit /etc/X11/xorg.conf
Add
Option "RegistryDwords" "EnableBrightnessControl=1"
to the “Device” section so it looks somewhat like this:
Section "Device"
Identifier  "Default Device"
Option  "NoLogo"    "True"
EndSection
Then restart the X server.
Eliah Kagan
  • 119,640
sergwy
  • 31
I suggest that you use Ubuntu 11.10. And install all the available drivers from the Voria repo. Make sure you have nvidia_bl installed which is required to correctly manage brightness.
sergwy
  • 31
