I sometimes run into an issue where I try to run an app from the GNOME menu and nothing happens - the app name appears in the upper left and the spinny cursor comes up for a bit, but the application never launches.
I want to try to troubleshoot what is happening by running the same command, whatever it is, from the command line, to see what the output is. But I don't know what command is being run. If I right click on the icon in the menu, I see a "Show Details" option. But it doesn't work the way I expect - it takes me to the software center, which sometimes isn't even right because it's not there. But in no case does it actually give me a clue as to what the command line is that it is invoking.
Where can I find this information?
update: I found a related question which got me the information - I found that "menulibre" was already installed by default. It didn't solve my initial problem though, because the command ran find from the command line.
