I recently deleted Windows from my Laptop and installed Ubuntu to use it as a main operating system (no other operating system beside Ubuntu installed). So I want to delete Ubuntu now. I want no operating system on my Laptop. How can I do it?
Simply delete all partitions and data from your hard disk.
You can make a bootable USB that contains a disk manager like gparted, or just use GUI tools like "Disks" in a live Ubuntu session by selecting "Try Ubuntu" when booting from Ubuntu installation media. You can even use disk formatting tools from a Windows bootable USB.
- 12,664
If you want to remove all partitions, you can boot from a live usb and run fdisk -l to find your hard disk and then run fdisk /dev/sdX and type o to create a new MBR partition table. If you want a GPT partition table, you have to run gdisk /dev/sdX and type o to cerate a new GPT partition table. To write and exit type w. To abort write q.
For example
# fdisk -l
Disk /dev/sda: 149.05 GiB, 160041885696 bytes, 312581808 sectors
Disk model:
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 457A8416-1E69-4BB7-B84A-E731240D648E
Device Start End Sectors Size Type
/dev/sda1 2048 18431 16384 8M BIOS boot
/dev/sda2 18432 1067007 1048576 512M EFI System
/dev/sda3 1067008 273696767 272629760 130G Linux filesystem
/dev/sda4 273696768 312581774 38885007 18.5G Linux swap
Disk /dev/sdb: 30.05 GiB, 32262586368 bytes, 63012864 sectors
Disk model: USB Flash Disk
Disklabel type: dos
Disk identifier: 0x63a44614
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 0 2543423 2543424 1.2G 0 Empty
/dev/sdb2 172 131243 131072 64M ef EFI (FAT-12/16/32)
/dev/sda is the hard disk (150 GB) and /dev/sdb is the USB.
# fdisk /dev/sda
Welcome to fdisk (util-linux 2.36).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): o
Created a new DOS disklabel with disk identifier 0x5bd5b3e4.
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Creating a MBR partition table.
# gdisk /dev/sda
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Command (? for help): o
This option deletes all partitions and creates a new protective MBR.
Proceed? (Y/N): y
Command (? for help): w
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): y
OK; writing new GUID partition table (GPT) to /dev/sda.
The operation has completed successfully.
Creating a GPT partition table.
The data will still be recoverable (/on the disk), but it wouldn't show up in your file manager. If you want to erase it permanently (/overwrite it with random data) you can use fdisk -l to find the hard disk and use dd if=/dev/urandom of=/dev/sdX status=progress to overwritet it with random data and then use fdisk for a MBR partiton table and gdisk for a GPT partition table (see above)
For example:
# dd if=/dev/urandom of=/dev/sda status=progress
150000000000 bytes (139 GB, 150 GiB) copied, 882 s, 170 MB/s
292968750+0 records in
292968750+0 records out
150000000000 bytes (139 GB, 150 GiB) copied, 882.35294 s, 170 MB/s
Overwriting it with random data
See above for creating the partition tables
- 370
- 2
- 9
